CAMS 264/272 or 272/272? help!!
Old Jul 14, 2006 | 08:48 PM
donmeca2020's Avatar
alright before any flaming i have searched, the most i found while searching was mere opinions. does anybody know what would be the better set-up? im ready to purchase asap. so far the mods i have are injen intake UIP, costum 3inch exhaust, hallman MBC, and i just installed a s-afc2. forgot to mention the cam gears are here awaiting the cams, fuel pump, and headstuds. so which set up would be the best? any help would be greatly appreciated.
Old Jul 14, 2006 | 09:26 PM
bluebanana23's Avatar
272 straight so you won't have to upgrade again due to a larger turbo in the future. Great as a daily driver anyways.
Old Jul 14, 2006 | 10:05 PM
nigletsyz's Avatar
GSC 272/264 for street. I have heard great things about this combo
Old Jul 14, 2006 | 11:04 PM
i've heard the 264/272 combo is very good, but then i have heard the same about the 272/272 also. what are you guys both running?
Old Jul 15, 2006 | 10:57 AM
fsugatorbait's Avatar
Have it and love it. Pull 2 cars instantly on my buddies car with more mods and straight 272's.
Old Jul 15, 2006 | 11:50 AM
Ph3n1x's Avatar
280/280
Old Jul 15, 2006 | 12:25 PM
broeli's Avatar
You ask which setup would be best...best for what? You searched and got opinions..that's all your going to get again
With the 264/272 setup the only advantage will be a good idle to go along with good topend. IMO, if you have camgears there is no sense in getting the 264/272's. Get the 272/272's and set them at -4/-1 for good topend AND good idle...and you can play with the powerband even more by adjusting the cam timing if you don't care about idle but want lowend such as +1/-1.
Another good power making option for lowend lowend/midrange power is 272/264 setup.
Old Jul 15, 2006 | 01:14 PM
Utah-evo's Avatar
Broeli so without cam gears 272/264 and with cam gears 272/272 ? Also do you guys think a mail in reflash would be a good idea for cams? I live in the middle of nowhere :/
Old Jul 15, 2006 | 07:10 PM
yea well, maybe i just might go with the 272s. i mean i already have the gears so what the hell. ya know
Old Jul 16, 2006 | 04:12 PM
kaonashi's Avatar
ill tell you a secret, my friend has my same mods but with gsc cams, and i pulled him by a fender length from 40 mph to 100 with my stock cams and i have an 03, so i dunno if its the cams or what, he also has a tune which i dont have yet Dynoflash i believe.
Old Jul 16, 2006 | 04:31 PM
HPF Chris's Avatar
I've run the HKS 272/272 in both our EVO and my Supra. Idle is still very smooth and lag is barely noticeable as compared to the stock cams. We made 325whp with the stock turbo on pump, 402 with our HPF turbo on pump and so far 535whp with our HPF turbo on race fuel. This is with the entire motor stock except for the cams. Most of the time I'm deciding between 272's and 280's.
Take care,
Chris.
Old Jul 16, 2006 | 05:20 PM
Erik@MIL.SPEC's Avatar
I think with the 272/272 combo, it's all about setting the cam gears. A lot of guys have them at -3/-3 or -2/-2, but after seeing some comments from Ted B, +1/-1 or +2/0 may be better. The complaints about 272's that I have seen are about response @ tip in.
More people with the +1/-1 setup should chime in.
Old Jul 16, 2006 | 05:41 PM
chrisblueevo's Avatar
Well chris u saw what my 272 did to anothonys srt4. So there no question. I think u should try the 272/264 setup. Jeff has that in his evo and he made like 370hp and ran a 11.7 in the quarter. I only made 348 on my setup. SO try that combo it will also give u more tq
Old Jul 16, 2006 | 07:04 PM
possibly but, even as someone said before you, no need for that setup because i have cam gears. suposedlly its just not worth it. i dont know im still continplating
Old Jul 16, 2006 | 07:35 PM
Rnm's Avatar
Rnm
280/280
