Best Clutch/Flywheel Combo
Old Jul 20, 2006 | 04:28 PM
KartaRailed's Avatar
What is the best clutch/flywheel combo to hold about 500lbs of TQ. Im looking to spend about 800 dollars. If this is to little smack my high hopes down. I searched and it came up with a whole heap of useless threads. Clutch is to common a word on this forum.
Old Jul 20, 2006 | 04:53 PM
~EVILEVO~'s Avatar
$800 Good luck on that one! an install will run about $800
You have many options for clutchs. I wont say which clutch to go with, but I will tell you this No matter what ANYONE here on this board tells you there WILL be pros and cons for EVERY clutch! That said just do a little research you will find everything you need to know on the interweb Goodluck
Old Jul 20, 2006 | 05:32 PM
I didnt say to include an install price, i just need to know the price for the parts and the best for the money. I already know who will install the clutch+flywheel for me, They quoted me 500 for just about any clutch+flywheel. I'm looking to spend about 800 for the parts. Thanks for input.
Old Jul 20, 2006 | 05:56 PM
Evolution8Blue's Avatar
if your only needing about 500 ft/lbs....id say the best for that much would be the act makes some good ones for that power range...then pick a flywheel
Old Jul 20, 2006 | 06:07 PM
nigletsyz's Avatar
ACT Xtreme pressure plate and your choice of street disc or 6-puck.
Old Jul 20, 2006 | 06:15 PM
AF-Evo8's Avatar
one of the guys on here is selling this you might want to try your luck and see if you can win it would be well worth it.
https://www.evolutionm.net/forums/members/30718-akgvr4riceater.html
and his clutch is here:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old Jul 20, 2006 | 06:24 PM
superflyevo's Avatar
exedy twin
Old Jul 20, 2006 | 06:28 PM
<4G63>Inside's Avatar
Originally Posted by superflyevo
exedy twin
If you find one for $800 let me know!
Edit: Just noticed the link was that cheap for a used 1. Not too sure about buying a used clutch though!
Old Jul 20, 2006 | 06:44 PM
Yeah... a used clutch sounds like a crappy idea. Thats like buying used tires or brake pads to me. I dont think i could do it.
Old Jul 20, 2006 | 06:47 PM
AF-Evo8's Avatar
not when the clutch is only used 2 weeks and its re-buildable
Unless I knew the person that is! The clutch in the link says only 2 weeks of "light" use. It also "looks" to be in VERY good condition. You just take a big chance going used. I will probably go ACT Stage 1 or 2, or WORKS stage 2 w/ flywheel.
Old Jul 20, 2006 | 06:51 PM
AF-Evo8's Avatar
if it truly was 2 weeks of light use than it would be worth it
Old Jul 20, 2006 | 06:56 PM
Hell yeah! If someone buys it for under $800, and has no issues after install, it would be the deal of the year!
Old Jul 20, 2006 | 07:00 PM
EvO6-RS2's Avatar
For that $$ you could get ACT 6-Puck 'sprung' hub with xtreme p/plate & streelite flywheel..I ordered that today..hope it's a good combo.
AF-Evo8's Avatar
kartarailed don't overlook that clutch, talk to the guy and see what you can find out it would be a crazy deal.
