Need URGENT help please
Old Jul 21, 2006 | 10:57 AM
WHTEVO's Avatar
Originally Posted by Rui Evo
humm never heard of the eliminator kit,can u link me one so i cay buy it please?
They can also be found at shops such as amsperformance.com , buschurracing.com , lancershop.com etc.
You will look under the engine parts for a balance shaft eliminator kit.
Old Jul 21, 2006 | 12:18 PM
Rui Evo's Avatar
what does that do? i mean..i cant see where it helps me?
i found this one
http://www.extremepsi.com/store/cust...=17650&cat=756
but cant see how it helps me...
Old Jul 21, 2006 | 12:30 PM
Stew's Avatar
Are you using a 4G63 oil pump with a 4G64? I'm not sure off the top of my head, but maybe the 2.4 4G64 isn't compatable with the 2.0L 4G63 oil pump?
Old Jul 21, 2006 | 12:34 PM
Rui Evo's Avatar
hi mate,yes my problem is when it hits the oil pump..i own a mitsu evo 6 and now i dunno what to do...
Old Jul 21, 2006 | 12:35 PM
WhtEvo05's Avatar
Call AMS or Buschur I'm sure they can help you out over the phone instead of driving yourself crazy trying to figure it out.
Good luck
Old Jul 21, 2006 | 12:37 PM
Rui Evo's Avatar
well i have the 4G63 oil pump which is the stock one,but after stroked my block to 2.4 it hits there.
Old Jul 21, 2006 | 12:39 PM
Rui Evo's Avatar
here is my spec..
Uk evo 7 short block built by JAM Racing to the following spec:*ARP main studs
*New 2.4 Forged Steel Crankshaft
*Venolia Forged Pistons, 8.5-1 cr
*Oliver Billet Conn Rods
*JAM~File to fit ring package
*Perf coated ACL rod & main brgs
*ARP main studs
*Balanced as a complete assembly Engine
but now the oil pump doesnt work fine here and in movement it touches like in the photos ive posted.
Old Jul 21, 2006 | 12:45 PM
Stew's Avatar
Why don't you look around your area for a 4G64 oil pump and try that out?
Old Jul 21, 2006 | 12:53 PM
Rui Evo's Avatar
what mitsu model is that?
Old Jul 21, 2006 | 12:59 PM
Stew's Avatar
Mitsubishi Galant, Eclipse, etc.
Old Jul 21, 2006 | 01:05 PM
Rui Evo's Avatar
ok thankz and what about removing the balancer shafts, Get a eliminator kit ?
Old Jul 21, 2006 | 09:04 PM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Rui,
Who sold you the engine parts? They should be able to help. If not, you can try Buschur or AMS. They've probably built more strokers than anyone else out there.
Old Jul 21, 2006 | 09:36 PM
CO_VR4's Avatar
here is my spec..
*ARP main studs
If JAM built your entire short block, ask them which oil pump/cover is designed to fit with the clearances they built into the short block. Since it's balanced as a complete assembly now, you don't want to start massaging or grinding clearance now. It should be their problem for the money you paid for a complete shortblock.
Old Jul 21, 2006 | 10:02 PM
joeymia's Avatar
i think it is hitting because the balance shaft is supose to turn with the motor. if you turn the balance shaft at some point does it not hit? The oil pump has a timing mark for a reason...
Old Jul 22, 2006 | 08:18 AM
Rui Evo's Avatar
thats exactly how it is...how can i fix this problem?
