Single clutch
Old Jul 27, 2006 | 06:28 AM
evokw's Avatar
Single clutch
Hello there guys. Im planing on getting a single clutch uprade with a flywheel. But the thing is that i heard that the ACT sinle clutch locks you out of gear above 7000 rpm. is that true? if it is then what should i get? i dont want a double clutch cuz its to expensive. ill be fine with up to $800. what do you guys sudjest?
Old Jul 27, 2006 | 06:32 AM
Smike's Avatar
wow...so been talked about a lot before...darn you invisible search button darn you!
ACT is fine when adjusted right. Or you could just get 6/4/3(RalliArt) puck.
Old Jul 27, 2006 | 06:42 AM
evokw's Avatar
LOL hay funny guy SmikeEvo. I did use the invisible search button. But there were no sudjestions on a good single clutch. Would a six puck clutch work fine for DD? and if yes were can i find the Ralliart clutch?
Old Jul 27, 2006 | 07:06 AM
Smike's Avatar
I know a bunch of guys using a puck clutch as a DD. Takes some learning at first, but they like it.
If you really want the RA - PM EvoGLH - he has the RalliArt 3 puck. He can tell you all about it.
EDIT: Ill add though, using a heavier duty cluctch will put more stress on other parts i.e. trans parts, etc. Id rather have my clutch blow v. my trans going...just some more food for thought.
Old Jul 27, 2006 | 11:17 AM
evokw's Avatar
I am aware that there will be stress on other parts of the car. But i do not drive my car had at all. I rarely lanch it.
Old Jul 27, 2006 | 11:46 AM
fastct9a's Avatar
im in for it also my car just let the stock clutch go at 73k miles. I would like something also that doenst lock out after 7k cuz i find myself there quite often on the weekends.
