Evo 8 spark plugs do not fit a 9
Originally Posted by SuperHatch
Where is the documented source you heard this from? I.E. - Mitsubishi Engineering Documents. Because until you do, this is completely conjecture, and very poor at that.
The only benefit I see of a taller surface between the top of the combustion chamber and the base of the spark plug valley is more room for cooling passages, which makes much more sense than an effort to eliminate "lifter tick".
Originally Posted by housedj
well its in the '06 brochure that the head is taller. now they don't actually say that the head is taller to elimiante lifter tick but common sense would tell us that since the MIVEC required a taller head & longer spark plugs that would essentially rid cammed EVOs from that problem...
-Paul
Originally Posted by Inprogress
Any update if there is a 1 step colder plug available for the EVO IX?
HKS Part number: S40iL
OE NGK number: ILFR7H
Stock Plug= NGK ILFR7H Stock #5245 LINK
Step colder= NGK R7437-8 Stock #4901 LINK
2 Steps colder= NGK R7437-9 Stock #4654 LINK
3 Steps colder= NGK R7437-10 Stock #4655 LINK
NGK ILFR7H (OEM) Iridium
http://www.sparkplugs.com/more_info.asp?AAIA=&pid=20451
NGK LFR7AIX Iridium
http://www.sparkplugs.com/more_info.asp?AAIA=&pid=16602
NGK LFR7AIX Iridium
According to NGK Techs, the two plugs are the same except for two minor differences.
ILFR7H - OEM GAPPED AT .024" PLATINUM TIPPED ELECTRODE
LFR7AIX - SAME DIMENSIONS, GAPPED AT .028" (WILL NEED TO BE ADJUSTED) AND ELECTRODE IS NOT PLATIMUM TIPPED.
Difference is the OEM will last longer and will not need to have the gap adjusted. For a difference of $4 a plug, you can adjust the gap and change it at 20K, instead of 30K.
Done
210
Apr 4, 2015 10:47 PM
Evosick2332
330
Nov 10, 2010 09:41 PM
TheGreek
Apr 28, 2009 09:21 AM
