Gas pedal adjustment
Old Aug 11, 2006 | 09:27 AM
fixem2's Avatar
Anyone had an issue with the gas pedal not going to the floor far enough. The reason for the question is that I have been loggind my ECU via EcuScan and noticed the TPS % is 98.6 or 99 most of the time when I am at WOT. The only time I get 100 is when I force my foot through the firewall (Figuratively). My thought is the pedal stopper is too high. I haven't look at it, but is it a screw type of adjustment?
Thanks in advance.
Old Aug 11, 2006 | 09:34 AM
justchil's Avatar
It should be all the way down. I think it just kinda snaps in there... you may also make sure the carpet/floormat isnt getting in the way.
Old Aug 11, 2006 | 10:35 AM
fixem2's Avatar
I will check after work, but I keep forgetting. Hard to log when you aren't hitting 100%!!
Old Aug 11, 2006 | 10:41 AM
idriveanevo's Avatar
the adjustment is on the intake, ist held on by two 10mm bolts.... i had to adjust mine to.
Old Aug 11, 2006 | 11:25 AM
fixem2's Avatar
So you are saying yours had to much slack in the line and you took that out via the slide adjustment on the intake.
Old Aug 11, 2006 | 11:32 AM
right, i had about a half inch of play in mine....
justchil's Avatar
You should probably do that anyways. Leave a little bit of slack but normally from the factory they have alot.
Old Aug 11, 2006 | 11:39 AM
well it wasnt oppening all the way so i tightened it, make a difference in mine....
Old Aug 11, 2006 | 12:16 PM
fixem2's Avatar
Did that on my 03, but totally forgot about it on this one and I have had it for a year!! doh!!
This should help me with the logging and to verify that I am at full WOT!!
