launch rev limiter
So after reading thread after thread about how to launch, I decided to actually check if there was actually a 5k launch limiter. AND.....yeah NO launch limiter. I didnt over-rev into the red but it did surprise me as it jumped to 7k. What's the deal? Is this a new ECU version? I just got my IX a month ago.
I had the clutch in but i had it at the level before actual engagement. Should it be on the floor? I guess there's a possibility that it was slightly rolling. I just wanted to prove it to a friend last night, as we were discussing it. I'll have to try it again sometime soon
You have it & I am sure that you can make it happen half way pressed because the switch that activates this is located at the back of the clutch pedal arm but I will not recommend that because you will burn your clutch. If you dont want this 5k rev limiter it is very easy to remove, just un-plug the switch. I have done this already.
Originally Posted by SiCKlEyWiKeD
You have it, you just didn't do it right.
And for safety, when youre coming to a stop after moving. Come to a complete stop, put it in neutral, let off clutch, then put clutch back in and put in gear; then go.
Originally Posted by HaVoK23
Don't you have to be engaged into first also? Or just the clutch depressed? Not sure.
