20g records, Stock Appearing Class etc.....
Old Aug 24, 2006 | 06:28 AM
  #121
Zeus's Avatar
I might be interested in a new turbo now...
Old Aug 25, 2006 | 09:16 AM
  #122
Turbo Kyle's Avatar
When you guys say 20g-9-5. Are you talking about the 20G 5 blade wheel with the 9.5 hot side? Sorry I am a new just trying to learn. I have a New 06 Evo 9 and Im about to spend some money. I know the Evo 9 has the 10.5 hot side.
Old Aug 25, 2006 | 09:25 AM
  #123
JohnBradley's Avatar
Originally Posted by dadriva
Car is a BR stg 4 w/ 20-g-9-5 and alky.
2nd pass 94 + alky 27.5 psi
1.62 60ft 11.63@117
3rd pass 114 oct NO alky 29 psi
1.70 60ft 11.64@118
Interesting that the numbers are so similar with pump + alky versus race gas.
All in all I'm very happy with this full weight, stock appearing car.
What I find really interesting is the actual effect of the meth on total octane rating. Runs 2 and 3 in particular. You had to run 1.5psi more boost on racegas for the same time (more or less) though I realise the 60' difference would have made the pass faster. Good job, and it makes me happy to see what I am gonna be capable of next season.
Old Aug 25, 2006 | 09:43 AM
  #124
justchil's Avatar
The 20G-9-5 has a 10.5 hotside.
dadriva: what were your 1/8 mile traps/ET's?
Old Aug 25, 2006 | 09:51 AM
  #125
Turbo Kyle's Avatar
And what does the "9" mean? Thanks in advance
Old Aug 25, 2006 | 09:55 AM
  #126
The 9 means IX as in Ti-Al IX hardware.
Old Aug 25, 2006 | 10:01 AM
  #127
Turbo Kyle's Avatar
And Ti-Al means IX turbine wheel and compressor cover?
Old Aug 25, 2006 | 10:08 AM
  #128
PVD04's Avatar
The 9 actually means IX as in the IX compressor cover.
Old Aug 25, 2006 | 10:32 AM
  #129
David Buschur's Avatar
Here is a break down of the turbo description:
20g-9-5.
20g is a wheel we originally built with another company, it had 6 blades and was a reversed copy of Mitsubishi's 20g wheel. Mid-build I changed companies that made the turbos but didn't want to change the name of the turbo so the "20g" stuck.
The "9" is the turbo we base the build from, this is the larger compressor covered EVO9 turbo.
The "5" is the description of the new, actual, compressor wheel we are using, which has 5 blades instead of 6 like the original 20g wheel did.
That's it.
Old Aug 25, 2006 | 11:01 AM
  #130
Turbo Kyle's Avatar
20g-9-5.
That's it.
Thanks Dave,
I have access to one of your 5 blade 20G turbos. I was going to aquire it for myself, however I might wait for the new one you are working on. I know you cant throw out any info as af yet (as far as specs go). How much would it cost to upgrade the 5 blade 20G to the new monster you are working on. I am going to assume that the new on has a diffrent turbine wheel.
Old Aug 25, 2006 | 11:16 AM
  #131
Kee1pride's Avatar
Is it possible you're going to lower the price on the current 20g-9-5 since most everyone will be wanting the big boy?
Old Aug 25, 2006 | 02:14 PM
  #132
4G63 T's Avatar
Buschur,
ETA please for this new turbo.
Thanks.
Old Aug 25, 2006 | 02:26 PM
  #133
ibanez_926's Avatar
its amazing the amount of hype dave produces on this site.
I resisted the last 20g since i 95% of the time run 93 octane pump gas.
We shall see how this new one performs on the ole 93 octane
Old Aug 28, 2006 | 07:25 AM
  #134
Not sure on pricing on old or new as of right now. I've tested two variations of this turbo already. The data has been reviewed and both turbos are out having more changes done to them right now.
The price on either of these new ones I tested I am going to guess will be slightly higher. The current turbo is the fastest spooling of the three. I don't know that everyone is going to want the newest versions for that reason.
Old Aug 28, 2006 | 07:52 AM
  #135
jbrown's Avatar
Keep working on it man, we want the best turbo you can come up with!
Even if it takes a little longer.
