o2 housing and port exhaust manifold
Old Aug 16, 2006 | 04:09 PM
EvoDan2004's Avatar
Originally Posted by althemean
does BR just do gasket matching when he ports the exh mani? Or is there more to it than that?
call and ask but i beleave they port match/gasketmatch everything. i got my 10.5, manifold, o2 all done and this is how he did it. came out great
Old Aug 16, 2006 | 04:12 PM
althemean's Avatar
Sometimes DB does not like to give out his secrets.....I dont blame him.
Old Aug 16, 2006 | 04:13 PM
olsookie's Avatar
now there is another perfect example as to why a new thread is never a wasted thread. he saw it, you started b/s, i responded, he than had a question...
Old Aug 16, 2006 | 04:21 PM
EvoDan2004's Avatar
and that question was also asked in the other 72 threads.
just get the parts and put them on. you will see gains but get a tune or flash for optimal gains. also you may want a 10.5 hotside if your evo has a 9.8 on it.
do you have a d/p? cat delete pipe? i dident see your mod list.
Old Aug 16, 2006 | 04:23 PM
EvoDan2004's Avatar
ok so you got an 05 evo. so no need for a 10.5 hotside. but get it ported while sending out the manifold and o2. you got a tbe in your sig so there for your set to go after a nice tune. yes you will now see some nice gains.
Old Aug 16, 2006 | 04:32 PM
olsookie's Avatar
Yes
I have an 05 - 8
BR TBE Exhaust w/ Cat
HKS RS Intake
Perrin Front Mount w/ short route piping w/ Greddy RS BOV and Turbo XS MBC
GSC Cams 272ex 272in
Old Aug 16, 2006 | 04:33 PM
olsookie's Avatar
lol, now that wasn't hard was it?
i bet it was killing you to type that out though... man.. fingers probably hurt!
Old Aug 16, 2006 | 04:34 PM
EvoDan2004's Avatar
Yes
I have an 05 - 8
HKS RS Intake
no hopes for a cat delete pipe? that will show you nice gains as well. then add the parts i said and parts you want and you should see some nice gains after a good tune.
Old Aug 16, 2006 | 04:53 PM
EVOlutionary's Avatar
WIth the mods that i have listed in my signature, would there be any significant gains of WHP if i were to go with an aftermarket 02 housing and a ported exhaust manifold?
Thanks
olsookie
Yes.
You ask, I answer, easy as that!
EVOlutionary
Old Aug 16, 2006 | 06:21 PM
sparky's Avatar
Yeah, Buschur recorded about a 15 whp gain with the Ebay O2 housing alone, in his Dyno Thread. The ported manifold and a ported HS should add a bit as well. All told it should be at least a 20 WHP increment, plus some collateral gains, like improved spool-up and reduced back pressure. Go for it!
