Tilton Pedal Stop
Old Aug 27, 2006 | 11:07 AM
Noogles's Avatar
Tilton Pedal Stop
I'm Uncertain if it's needed, however the shop doing the install swears it is needed and without it you will overextend the TOB and blow the seals.
Is this True? If so who Sells the Stopeer?
Old Aug 27, 2006 | 11:29 AM
bpclements's Avatar
The pedal can be adjusted down far enough with the clutch adjustment rod. Using the rod to move the engagement point all the way down is enough to fall within the tilton spec. I have done 3 tilton installs without the stop and I didn't have any problems adjusting the travel. This was before they came out with the clutch stop. It wouldn't hurt to get it. Also, make sure that they remove the helper over spring on the clutch pedal. This will make it much easier to drive.
Old Aug 27, 2006 | 11:39 AM
Agent-Smith's Avatar
Much easiar? That's an understatement
Old Aug 27, 2006 | 12:12 PM
Noogles's Avatar
Where is the Helper overspring located?
Anyone have a part # for the Pedal stop?
Old Aug 27, 2006 | 12:48 PM
bpclements's Avatar
It is a spring up behind the clutch pedal. It is shown in the Evo specific instructions that came with the Tilton.
For the pedal stop, send TTP Engineering a PM. I'm sure they can help you.
detroit pistins
Feb 19, 2017 06:50 PM
Chet3215
Jan 21, 2017 06:12 AM
Mivo
Northwest Region
11
May 13, 2011 09:28 AM
HELLBOY
Feb 26, 2005 06:14 PM
