tilton twin cerametallic owners
Old Aug 27, 2006 | 02:27 PM
superflyevo's Avatar
i searched ,read a bunch about this clutch wanted to see if there was any updates on this clutch. i will be installing mine friday this week.
i seen that it is over 10 lbs lighter than the stocker so can you guys tell a big differance in reving did the shaved weight make a big differance
i have a exedy twin in right now i read the total weight of the exedy is 28lbs
the tilton weighs in at 19lbs
let me know what you think about your tilton twin cerametallic
Old Aug 27, 2006 | 05:53 PM
anyone??
Old Aug 28, 2006 | 12:29 PM
no tilton guys out there??
Old Aug 28, 2006 | 12:35 PM
EVOlutionary's Avatar
Does the 19lbs include the weight of the flywheel? If so, that's extremely light!! Don't know how they could get it that light.
I'll bet on the Exedy the flywheel is included in the weight you listed. Exedy uses a steel flywheel.
EVOlutionary
Old Aug 28, 2006 | 01:09 PM
tilton is 19lbs flywheel/clutch everything
Old Aug 28, 2006 | 02:51 PM
johannes's Avatar
It is easier to rev-match, and I can shift a bit more quickly. I'm just glad I don't live in San Francisco!
Johannes
Old Aug 28, 2006 | 04:13 PM
jus got it in the mail cant wait to get it in
Old Aug 28, 2006 | 04:19 PM
joeymia's Avatar
another tip i don't see mentioned much is when coming to a stop keep the car in gear. let it rev down to about 2k before you clutch in and get it out of gear. If you just clutch in at the same time while breaking the car tends to want to stall.
Old Aug 28, 2006 | 05:23 PM
does the engine seem more responsive (rev faster)
with all that weight taken off the rotating mass
Old Aug 29, 2006 | 01:56 AM
Ang Wen Yan's Avatar
Of course!!1lb of rotting mass = 4lb of weight you taken from non rotating mass
Old Aug 29, 2006 | 07:13 AM
TurboSpoolinIns's Avatar
I liked it when it worked, but I'm never buying one again. The only one I'd buy is a Carbon Carbon but I'm still not satisfied w/ Tilton's cust. service.
Old Aug 29, 2006 | 08:03 AM
Zeus's Avatar
...and carbon is not good for a daily driver.
Old Aug 29, 2006 | 08:23 AM
The cerametallic wasn't great for daily driving either. I'm sure the CC is just as good/bad. I've driven other C/C and they would be just as "good". -Not trying to argue, just stating.
Old Aug 29, 2006 | 08:33 AM
johannes's Avatar
What do you believe is wrong with the twin cerametallic as a daily driver? Mine seems just fine. I have about 3-4K on it right now, with a few track events.
Johannes
Old Aug 29, 2006 | 08:37 AM
Johannes
I don't believe anything is wrong with it. I just was stating it's probably as "good" as the carbon for daily driving.
