Clutch or transmision issue?
Old Aug 29, 2006 | 05:11 AM
Ducu's Avatar
After i changed my clutch with an exedy organic single disc kit i can not shift properly.
At high rpms 6500-7000 it goes very hard into 2 and sometimes 3rd as well.
Is it a transmision thing... or its becouse of the clutch?
At lower rpms its perfect...
THX
PS. the clutch grabs high so i was thinking its no need to adjust the clutch rod.
and it shifts perfect untill 6000 rpm so i think its no need to bleed it either..?
Old Aug 29, 2006 | 05:37 AM
GTVEVO's Avatar
Yep sounds like you need to adjust the clutch petal/rod. This has to be done with any clutch install so I would do that first to see if it helps your issue, sounds like it will.
Old Aug 29, 2006 | 05:55 AM
4Gsixty3's Avatar
www.evomoto.com
search that site and u will find the "how to" adjust the clutch pedal!!!
Old Aug 29, 2006 | 06:03 AM
Smike's Avatar
+1 4G
Here is the direct link:
http://evomoto.com/tech_info.php?tec...fb6355983bc739
You know you have to break-in the clutch before you beat the **** out of it - right?
Old Aug 29, 2006 | 08:35 AM
Ducu's Avatar
Guys...thx a lot!
I have the clutch for about 1000 miles allready!
And i had this problem only at high rpms!... i said i had!!!
I just ajusted the rod the clutch its higher now... BUT IT WORKS JUST PERFECT!!!
Respect for you guys!!!
Old Aug 29, 2006 | 08:38 AM
Smike's Avatar
