Some help please
Old Aug 30, 2006 | 05:05 PM
apevo8's Avatar
Some help please
i have had my ECU flashed again because i thought that it was not tuned for part throttle, but once i put it in the car, it is doing the same thing again, the car will idle very wildley, and part throttle does not work properly, as soon as i put my foot on the pedal it will go for like 1k rpm, then jerk, then pause for a bit, then go again until i hit redline....wat the hell is wrong with the car??...if i press the pedal all the way down, it runs fine, and its only boosting like 15lbs.....is there a boost leak, or the throttle body has a problem, or the intake.....i have no idea....????????
