tore an o-ring! (what size to replace)
yesterday we finished installing my cluch/flywheel and we took it out for a little ride. when we got back we noticed a oil spot under the car. after further investigation we found that the larger o-ring up around the half shaft had ripped. i am going to purchase this o-ring and the smaller one(about a inch in size) to replace the two. my question is wich size do i need to purchase of both of the o-rings? all replies are greatly appreciated.
- tore
you can also msg. me on aim @ rev8lutioneight if you can give me this information!
edit:
i got the part numbers;
MD743612 o-ring between transfer case and transmission small
MD727944 O-ring netween transfer case and transmission large
im just curious if i can pick these up at a autozone or pep boys!
- tore
edit:
