broken stud on fuel pump retaining black ring how to fix?
Old Sep 7, 2006 | 07:00 PM
jrsimon27's Avatar
i changed my fuel filter today the problem i have is that when i was tightening the bolts that secure the fuel pump i broked the stud so how do i fix this??
Old Sep 7, 2006 | 07:05 PM
Tpayne84's Avatar
i did the same thing... if its only one than dont worry about it, the others are holding it just fine.
Old Sep 7, 2006 | 07:06 PM
jrsimon27's Avatar
have you ever had a leak with 1 broked??
Old Sep 7, 2006 | 07:08 PM
Tpayne84's Avatar
no not yet (knock on wood). you still have that seal on the inside right? if so than your good.
Old Sep 7, 2006 | 07:11 PM
jrsimon27's Avatar
ill check on the seal but thanks.
what i did was that i filled up the car with gas and went to drive and i moved the car from side to side and then i looked and had no leak but ill see what i can do
anymore ideas out there??
Old Sep 7, 2006 | 07:12 PM
ibanez_926's Avatar
mine has had 5 for about 1.5 years. no leaks
Old Sep 7, 2006 | 07:15 PM
jrsimon27's Avatar
thats a real relieve thanks, did you ever try to fix it?
Old Sep 7, 2006 | 07:16 PM
Tpayne84's Avatar
and i thought i was the only one that did this
Old Sep 7, 2006 | 07:18 PM
jrsimon27's Avatar
know we are 3!
Old Sep 24, 2011 | 07:17 PM
Steelo's Avatar
I was hoping someone would have posted a resolution for the predicament that I'm in. I just switched out my fuel pump and now have only one stud left. I have serious leaking and need to figure this out quickly.
Anyone have any ideas, feel free to pass them along.
Old Mar 16, 2013 | 01:47 AM
Deeeeej1973's Avatar
BUMP^^^ Can anybody please offer some advice on this? It would be greatly appreciated! Mine were rusted badly and snapped as well....
Old Mar 15, 2016 | 09:44 AM
Pal215's Avatar
Back from the dead. This just happened to me yesterday. Pretty sure the only real solution is to buy a new gas tank. Even if you drill out the studs and JB weld them on to the other side with new studs, that would be a temporary fix.
Looking for a whole new gas tank now.
-pal215
Old Mar 15, 2016 | 09:56 AM
kaj's Avatar
kaj
FWIW, those studs tighten to just a few INCH lbs.
They shouldn't ever break. Be careful
Old Mar 15, 2016 | 10:15 AM
Pal215's Avatar
yeah, I should have known this. What a rookie mistake on my part.
MN106179 is the tank part number and I can't seem to find it anywhere for a decent price Might just make a WTB thread and see if anyone here has one around.
Expensive lesson learned.
-pal215
Old Mar 15, 2016 | 10:20 AM
Biggiesacks's Avatar
if you are planning on replacing the tank then you will be removing it anyway, so just take it out and bring it to a local fab shop and have them repair it.
