Stock MAP sensor?
Old Sep 18, 2006 | 11:35 AM
Tuner@Swift's Avatar
Stock MAP sensor?
Is there one? If so, where? Sorry if this is a stupid question.
Old Sep 18, 2006 | 03:49 PM
alicea8541's Avatar
No, this is a MAF sensor car not MAP. Mass air flow sensor is just after the intake box.
Old Sep 18, 2006 | 03:53 PM
RazorLab's Avatar
Yes there is a MAP sensor on the intake manifold.
Old Sep 18, 2006 | 03:54 PM
whitey4d's Avatar
Actually the car has BOTH. The MAF is used for fuel decisions and there is also a MAP sensor that is used for the control of the EGR valve. BUT doesnt not dictate fuel decisions.
Old Sep 18, 2006 | 03:56 PM
Nez136's Avatar
Correct
Old Sep 18, 2006 | 03:58 PM
alicea8541's Avatar
Thanks for the correction.
Old Sep 18, 2006 | 04:44 PM
Is it located on the front of the IM in the middle, or towards the end. Also, is the signal a linear 0-5v output? And finally, does anyone know the voltage to pressure scale? I'm curious because I want to log a pressure signal, but not buy a 3bar MAP sensor.
Old Sep 18, 2006 | 04:46 PM
RazorLab's Avatar
The USDM evo 9 MAP only reads to about 0 vac. The UK evo 9 reads positive I believe. User jcsbanks I believe has more info about this.
