Turbotrix 50trim Kit @ the Dyno
Old Sep 22, 2006 | 09:20 PM
Paul Nelson's Avatar
congratz very nice #s
Old Sep 22, 2006 | 09:25 PM
Blue Evo 8's Avatar
Nice numbers I was around 410 or so on pump as well
Old Sep 22, 2006 | 11:13 PM
2StepsAhead's Avatar
Originally Posted by t51quicksilver
I got a question... Nice numbers by the way and please don't take anything I'm about to say negative as I'm in the market right now for a 50 trim kit as well from Shearer. I was under the impression that this turbo would make a little more power at that boost level especially with the mods you have listed in your sig. From what I've read in the past and I may be remembering incorrectly but I thought I saw some of the IX guys making nearly 400 HP to the wheels with similar mods to yours on the stock IX turbo with the boost your running. I realize your car is not a IX but most of the freak HP numbers from the IX to the XIII we see are do to the Turbo differences and not MIVEC so my question is by going to this turbo kit I really would not see much in terms of HP/TQ gains? Am I correct in assuming this? It would be fullish for me to spend 4K dollars and have almost near the same HP as my stock turbo with actually more lag. If anyone can shed some light for me or refresh my memory if my facts are incorrect I would appreciate it. My real goal is to have a daily driver that makes a solid 400HP on straight 93 with moderate boost levels ie. 19 maybe 20 psi to be on the safe side. Are my expectations unrealistic?
Thanks,
Joe
IX's with stock turbos don't touch 400 whp on pump gas, need an alcohol kit for 390ish whp and the cams for IX are sketchy right now...where as a pump gas 50 trim will clear 400 whp and then some.
Old Sep 23, 2006 | 06:20 AM
TurbotrixRacing's Avatar
Originally Posted by Smogrunner
I like how Gadiel signed your dyno sheet. 23.4 is a lot of boost for pump gas. On big turbos, we usually have to limit ourselves to around 21 psi on our crappy 91 octane in Calilfornia. You power curve looks like a lot of fun....
Maybe .. on CA gas .. 23 ..is alot, but not in PR.. nor NJ ...
Mark
turbotrix
Through a flash. ... that is awesome power for pump gas .. Keep in mind that this is SAE numbers .. add around 20whp for uncorrected numbers
Old Sep 23, 2006 | 09:06 AM
Soon2BEVO's Avatar
Good numbers Randy. I find most impressive however is your torque. It seems most 50trim dynos I have seen on pump gas only make around 340-360 with you clearing an awesome 378.
Everyone should keep in mind it was 91*F!! If it were 60* in there he would probably had 430whp+ no problem. Definitely get some track times on pump as for some reason it seems a lot of people have 50trims now but no track times. With that torque and over 400whp you should pull a GREAT trap.
Old Sep 23, 2006 | 09:55 AM
AlwaysinBoost's Avatar
kinda off topic but have you ever been to the track with your setup? I'm real curious to see your traps with all the tq you have...
Old Sep 23, 2006 | 10:06 AM
bluebyu36's Avatar
nice
Old Sep 23, 2006 | 07:21 PM
Randy's Avatar
Thanks,
Joe
I will answer your question in parts:
1. MIVEC does give a great difference in whp compared to an EVO 8
2. There is NO EVO 9 that is making 400 whp on pump gas straight and sane boost levels
3. The kit might be 4k but remember everyone is entitled to the choices thats why I decided to buy a turbo kit.
4. I have plenty of mods yes, but I used only 93 octane, on C16 or any type of alcohol injection and 30 psi of boost you would be surprised the power I can make.
5. The numbers are on SAE which is corrected taking into considerations the variables of humidity, temp etc. Uncorrected numbers you could add like 20whp so thats 435 on pump gas and add basically the same to the torque so its almost 400tq on 93 octane and 23 psi.
6. If you want 400 whp @ 19-20 psi of boost then I suggest you buy a GT35 but trust me the spool on that is going to be at 6k or more, that sucks IMHO for a daily driving car with spirited driving in some cases.
7. My car is a Road Racing vehicule, with sponsors and all, my AFR are on the RICH side, super safe AFR because I dont race only 12 seconds, I race heats of 15-20 minutes of abuse to the car. I need my engine to be as strong and safe as possible.
Old Sep 23, 2006 | 07:27 PM
Randy's Avatar
Track times, yes, I need to re-learn how to drive drag with this new set up, and the new clutch which Im having not problems but doubts heheh I used to dump the clutch with the stock one and pulled 1.6 or 1.7 most of the time when the track was prepped, but after a pass that I tried doing the same with the ACT my tranny is humming now, hate it will change fluids this week.
I took the car to the track lastnight, This is totally different the car bogged on the first pass, and missed 2nd and 4th gears, second pass pulled a 12.2 @117 having problems again with second, third pass 12.3 @117 with the same problems with 2nd and 4th, I expect this car to run 11.5 at least @ 120 mph.
Couldnt practice more with the car because of the rain track closed with my car next in line for the 4th pass.
I will go in 2 weeks, as this next weekend I have Road Racing event and thats where I really need to practice with my car.
Old Sep 23, 2006 | 07:29 PM
Randy's Avatar
Mark
turbotrix
Duh! You took the words out of my mouth.
Great kit awesome, need to improve my drag driving skills again!
Old Sep 23, 2006 | 07:57 PM
blueboost's Avatar
Sorry to hear man! Def something not right!
Old Sep 23, 2006 | 08:09 PM
Smogrunner's Avatar
Hey guys, I'm just jealous, not doubting the tune. Mark is WAAAY competent and his 50 trim kits seem to prove themselves over and over. They really shine on pump gas with their nice spool...
Old Sep 23, 2006 | 11:20 PM
IEXCELR8's Avatar
Nice numbers!!
Old Sep 24, 2006 | 08:53 AM
Creamo3's Avatar
Great numbers, w/ SAE correction the numbers already reflect the difference from an uncorrected number and take into account the heat/humidity already. So you would probably lose the 20hp not gain if it were to read uncorrected. Its the opposite scenario when it is cold out; uncorrected your numbers will be higher, but w/ SAE it will lower the number down. Great power.... gotta love the 50trim
Old Sep 24, 2006 | 07:35 PM
Randy's Avatar
Yes but if I changed the numbers from SAE to STD thats an additional 20whp and same in torque
