mbc problem
Old Oct 3, 2006 | 12:23 PM
Evo8zip's Avatar
Unhappy mbc problem
i just removed my turbo xs mbc for the hallman pro with the in cockpit controller and i have some problems. first, i started it up and it idled reallly low, def wasnt right. so i took it out and drove it. will boost to 12 psi and if i gas it past that it kinda backfires....so i thought maybe i hooked the vacum lines up wrong (the pic in the diagram showed the non cockpit controlled unit) so i switched them, started it up. idled fine so i thought, awesome it works. get on the road and have the same problem. i also took off the intake pipe to clean it up and theres a possibility the hose back to the bov is leaking but that wouldnt cause these problems would it? gonna let it cool down and go see what i can do...any input would be greatly appreciated!
Old Oct 3, 2006 | 12:38 PM
EVIL_EVO_VIII's Avatar
Sounds to me like one of the pipes is loose.. Recheck all the hoses and SPECIALLY the pipes
Old Oct 3, 2006 | 01:16 PM
Evo8zip's Avatar
haha ok...it dawned on me outta nowhere that i did something, well forgot to do something. always make sure you plug all of your harnesses back in thanks for the reply though evil! oh and hallman in cockpit mbc, thumbs up
Old Oct 3, 2006 | 01:18 PM
No prb. Glad you got it resolved
