My clutch is finally ****ed!!
Old Oct 8, 2006 | 08:24 AM
EVIL_EVO_VIII's Avatar
Well decided to go to the track friday night with my new tune and the addition of the walboro.. Lets say things didnt go as i planned.. Clutch slipped so bad all the way through 1st and 2nd that smoke came from under the car cause i over powered it and the car still managed to run 12.8 @ 108 with a 2.0 60ft!!.. I will need a new clutch this week.. I need some suggestions!! I got 28k out of the stocker pos
Old Oct 8, 2006 | 08:27 AM
smokedmustang's Avatar
Exedy HD twin metallic.
Old Oct 8, 2006 | 08:30 AM
derangedazn's Avatar
What are your goals?...... that will determine the type of clutch you will need
Old Oct 8, 2006 | 08:34 AM
Whp wise?
Old Oct 8, 2006 | 08:43 AM
hp, track use, lots of spirited driving? If you are going to for about 450 hp max with occasional track use then Stage 1 ACT will do. If you are trying to build an AMS killer (well now Burshur holds the fastest time last I read) then twin disc or higher is required.
Old Oct 8, 2006 | 08:45 AM
i dont go to the track alot.. But i want a 450whp set up
Old Oct 8, 2006 | 08:51 AM
ok. I have the same goals in mind, I was advised by several shops (I called over 10. inlcuding AMS, Burshur, and some other shops on the East coast) that a ACT 2900 Pressure with Street Disc and Lightened Flywheel (if you could afford it do so you wont have to take everything aprt again) will do. Pretty much that is a Stage 1 ACT setup which "should hold almost 500 lb-tq" You can find some great deals on here from several vendors
Old Oct 8, 2006 | 08:52 AM
Mike@Mynes's Avatar
ATS/Carbonetic Twin Carbon. See more info here:
https://www.evolutionm.net/forums/sh...11#post3323611
Old Oct 8, 2006 | 08:55 AM
You dont have to go with ACT, I tried researching on ACT versus Exedy but couldnt find a definate winner out of the two. But I am about to go put that clutch setup as I type I will let you know how it goes tonite or tomorrow
Old Oct 8, 2006 | 09:27 AM
I think im gona go with the ACT extreme with a light weight flywheel.. Let me know how it goes for you
Old Oct 8, 2006 | 09:36 AM
EvoGLH's Avatar
I have a Ralliart clutch with a lightened flywheel (basically, it's a Exedy Stage 2 3-puck cerametallic.)
Streetable enough (barely) for a daily driver, and rated to 450hp.
Took a bit to get used to it, but don't think I'll ever go to any other clutch type. Slippage & the smell of burnt clutch is a thing of the past...
Old Oct 8, 2006 | 09:37 AM
dsmfan95's Avatar
I'm using the ACT Super Street setup. It works good for lower power applications, but I would suggest the Extreme for a 450whp setup.
Old Oct 8, 2006 | 09:43 AM
EvoDan2004's Avatar
this is what im getting also. cant wait. im at 43500 miles and i beet the **** out of my car. i cant ***** about my cluch being ****ed up eather.
Old Oct 8, 2006 | 10:45 AM
justchil's Avatar
^^ Ditto for the Exedy HD twin metallic! I have the "non hd" which has made it through 2 years of drag racing
Old Oct 8, 2006 | 12:13 PM
BlueDemon's Avatar
damn miguel, that sucks big time and just right after wasting money on power mods now you have to spend even more on buying and installing a new clutch, ouch!
I hope you can get it fixed ASAP and at least thank god that it was only the clutch and not a gear or the transfer case!!!
