Snow Performance Meth kit. Questions and help
Old Oct 12, 2006 | 03:55 PM
evodrivesme's Avatar
I already searched but anways im picking my kit up from the guys up at slowboy racing on monday and am planin on bring it home and install it before i bring my car in to have the 30r and tune done. anways like i said i searched but does anyone have an install guide for these i have never delt with a meth injection kit before and well i just wanna know where its installed at a little bit about how it works, and if anyone can give me tips for my install that would be awsome.
thanks all!
Old Oct 12, 2006 | 05:44 PM
C6C6CH3vo's Avatar
Ask thenm directly for the instruction booklet. The kit is not as much of a snap together assembly as most the others, may require some fabricating, rigging, creativity, work. But it will pay off in the long run with reliability, if done good
Old Oct 12, 2006 | 05:52 PM
Ryu123's Avatar
If its like the kit I help a buddy installed this past weekend, its very straight forward. There are three wires coming out of the controller. Red (car's ignition), orange (goes to the red wire on the pump and red wire on the LED), and black (ground). The white wire on the LED and the black wire on the pump also goes to ground.
The hardest part is going to be finding a location to mount the pump cause its fairly large.
Old Oct 12, 2006 | 05:54 PM
DsmAwdTurbo's Avatar
what about the safe inj there is a wire that has to wire into the maf. what wire does it go to?
Old Oct 12, 2006 | 05:59 PM
Ryu123's Avatar
I kit I installed did not have the fail safe feature.
Old Oct 12, 2006 | 08:02 PM
well im going to check it 24/7 so i wont run out and im gettin the led one for sure. anyways so how does this work its not like some of the alcohol kits that just take out your old intercooler sprayer?
Old Oct 13, 2006 | 05:55 AM
C-Rolla's Avatar
Ryan,
This kit is pretty straight forward. Find a spot for the tank, run your lines, and then its a few very simple wires.
The kits do come with an instruction manual. :-)
Chris
Old Oct 13, 2006 | 06:00 AM
ya i meen i looked at the install instructions looks super easy im just trying to find a spot where i can install it. where do you guys usualy put your tanks?
Old Oct 21, 2006 | 05:36 PM
Ultimate CC's Avatar
If you have any install questions let me know...
Old Oct 21, 2006 | 05:37 PM
Here are a few pics of the kit installed on my EVO
Using OEM windshiled washer tank
Controllers mounted on passanger side floor
Tank and pump installed
Power led and warning led
Old Oct 21, 2006 | 05:38 PM
EVOLVEU's Avatar
Not to down anyone, but talk to Ultimate CC before you buy it. Dans the man when it comes to Snow Performance!
Old Oct 21, 2006 | 07:54 PM
althemean's Avatar
thats a nice install Ultimate..Not much capacity though huh? Do you turn it off for daily driving? Good setup for a drag car when you can refill/check between runs. It looks really stealth.
Old Oct 21, 2006 | 08:07 PM
Nope, I use meth day in and day out...I am at somewhere around 60 gallons through my evo so far...its a little over a gallon and it usually with spirited driving last half a tank or more of gas...I now have the pump mounted where it can be seen as its easier for me to show people who are interested in the kit...when I first installed it I was all about stealth and stock appearance...that has long gone though
Old Oct 21, 2006 | 08:08 PM
Old Oct 22, 2006 | 10:32 AM
althemean's Avatar
wow...I never realized that thing held that much fluid. I have never really emptied it though. I just top it off with windshield fluid once a month or so.
