208kw atw & 93% duty cycle on injectors ... why?
Subscribe
Oct 18, 2006 | 11:45 PM
I just had my EVO 9 tuned and it's currently making 208kw at the wheels. The tuner said my injectors are running at 93% duty cycle.
I thought the EVO 9 comes with 560cc injectors, so shouldn't that be good for up to 280kw or so?
So why is my injectors running at 93% or is that normal
Reply 0
Oct 18, 2006 | 11:50 PM
Any other mods? They do come with 560's. Id check over the tune.
Reply 0
Oct 18, 2006 | 11:52 PM
do you have a walbro fuel pump? A good fuel pump should lower your duty cycle a little
Reply 0
Oct 18, 2006 | 11:54 PM
Quote: Any other mods? They do come with 560's. Id check over the tune.
My mods are Haltech E11v2 ECU, TBE & IC piping, drop in filter and turbo inlet hose.
It's boosting at 22psi max.
Could the tune over run the injectors?
Reply 0
Oct 18, 2006 | 11:56 PM
Quote: do you have a walbro fuel pump? A good fuel pump should lower your duty cycle a little
I haven't considered a fuel pump yet, since I hear stock runs at 235l, but hearing you say that, it's next on my list.
Reply 0
Oct 18, 2006 | 11:59 PM
Quote: I haven't considered a fuel pump yet, since I hear stock runs at 235l, but hearing you say that, it's next on my list.
Get a second opinion first
I'm not perfect you know
Reply 0
Oct 19, 2006 | 12:04 AM
Nobodies perfect, but you can come close
Reply 0
Oct 19, 2006 | 12:05 AM
Quote: Nobodies perfect, but you can come close
haw i wish
I'll just make sure my better half is
Reply 0
Oct 19, 2006 | 12:07 AM
You need a fuel pump.
Reply 0
Oct 19, 2006 | 07:58 AM
Sounds like your not cutting enough fuel out. You should be able to run less timing and take more fuel out. You shouldn't need a fuel pump with minimal mods like exhaust and intake on the IX.
Reply 0
Oct 19, 2006 | 09:20 AM
Walbro 255 fuel pump is usually one of the first 3 mods we do here in the US--1) TBE, 2) Walbro 255, 3) flash (w/MBC). If you're tuning with a Haltech, you must get a Walbro IMO.
Reply 0
Oct 19, 2006 | 01:53 PM
Thanks guys, I'll get the Walbro pump. Why is it a must with the Haltech ECU?
Also with the pump should I still run less timing?
Reply 0
Oct 19, 2006 | 01:56 PM
I think most tuners use the pump as a bandaid... I'd take what most people are saying with a grain of salt.
Reply 0
Oct 19, 2006 | 06:45 PM
Quote: I just had my EVO 9 tuned and it's currently making 208kw at the wheels. The tuner said my injectors are running at 93% duty cycle.
Hey Stance, just read what MRT said about the fueling on page 9.
http://www.mrtrally.com.au/performan...ugust-2006.pdf
Reply 0
Subscribe
