another problem.. please help!!
Old Oct 21, 2006 | 04:53 PM
idriveanevo's Avatar
so i was leavng my car today and as i was walkng away i locked the doors with my key fob and the ac compressor kicked on and off twice with the lights... its happend before but it stopped now it started again... has anybody else had this problem or does anybody know whats wrong with it or can it be my turbo timer??
Old Oct 21, 2006 | 05:17 PM
help.....
Old Oct 21, 2006 | 06:12 PM
pleeeeease!!!
Old Oct 21, 2006 | 06:27 PM
RoadSpike's Avatar
Did the guys in the audio security section help you?
Old Oct 21, 2006 | 06:44 PM
nope...
Old Oct 21, 2006 | 06:52 PM
hotrod2448's Avatar
Factory key fob? Aftermarket alarm?
I see no way your stock keyless entry would do this so, I have to guess hacked up install on an aftermarket alarm.
Old Oct 21, 2006 | 06:55 PM
stock entry system, only electrical dne is a turbo timer with a plug and play harness. and an ebc.
Old Oct 21, 2006 | 06:58 PM
RoadSpike's Avatar
must be one of those devices crosswired with a/c line maybe as a ground or something.
If you turn on your a/c when its on do any of them experience issues/powerloss?
hotrod2448's Avatar
How do you know the A/C compressor is turning on and off? This sounds very strange because there really isn't easy to get them tapped into one another (at least not that I can think of off hand).
Are sure it isn't a bad engine fan relay flaking out and turning the engine fan on and off or something? There was a recall for it on the 03's.
Old Oct 21, 2006 | 07:01 PM
ive checkd everything and theres nothing crossed. the tt was installed with a plugin harness and its done it one before the ebc. idk how there could be a short or anything cause no wires have been cut or tapped into
Old Oct 21, 2006 | 07:02 PM
i know its the ac clutch cause i can see it kicking on and off as i hit the button
Old Oct 21, 2006 | 07:06 PM
hotrod2448's Avatar
Are you the original owner of the car?
Old Oct 21, 2006 | 07:08 PM
i bought it used but ive looked it completely over inside and out and nothing hase been touched..... i mean it was in perfect condition.....
Old Oct 21, 2006 | 07:21 PM
hotrod2448's Avatar
Obviously something isn't perfect. LOL
I really don't know much about the A/C system but, lets just go through it.
What engages the clutch on the compressor? I'm assuming voltage from the A/C switch. What ever it is it's apparently getting power from something that powers up when locking the doors. Whether it is the actual door locks or the lights that blink when locking. But, you made it sound like it's an intermittent thing. It was happening for a while then stopped and started again?
This would be much easier with a wiring diagram.
Old Oct 21, 2006 | 07:28 PM
it does it as the lights blink....
