Damn, a new rattle...
Old May 13, 2003 | 12:47 AM
Incognito's Avatar
I recently got a nasty little buzzing sound from the driver's side, right by where my left ear is. I was thinking it was the pillar where the top of the seat belt is mounted to. It's like a light buzz, that's there every so often. Finally found out (I think) is the driver's side window. When it's all the way up, I get the little buzz. If I crack it open (maybe 1/4"), the sound will go away.
Could it be a loose window glass already? Car is like 6 weeks old.
Old May 13, 2003 | 12:52 AM
azyan's Avatar
ahhh dam, this is the evo section, i have an oz and i hear a lil buzz exactly where you are talkin bout
Old May 13, 2003 | 11:21 PM
GannerBoy's Avatar
i've had 2 buzzes coming from drivers side, one was a little alarm unit box that was mounted on a rail under the dash near the valet switch (behind it), it was rattling like crazy because the strap used to mount it wasnt tight (dealer installed alarm).
the other buz seemed to come from the window/doorlock switches on the door, when i put my hand on it, it went away, but that only happened once.
Old May 16, 2003 | 10:07 AM
jotan82's Avatar
maybe the window gasket isn't on correctly or could be fallin off?
i would push all the black trim in with your hands and see if the problem is still constant...
let us know how it goes!
Old Jun 10, 2003 | 04:52 PM
WindsorLancer's Avatar
I'm getting the same rattle in the window , only it's in the front passenger side window.
Old Jun 10, 2003 | 08:56 PM
blue rocket's Avatar
i have the same rattle from the passenger side as well.
Old Jun 14, 2003 | 11:37 AM
OZLancer's Avatar
Same rattle - it's in my drivers side panel where the seatbelt is mounted - I just have to put pressure on it while it's rattling and it stops - probably a super easy fix if U care..
