Evo IX compression check #'s
Old Oct 25, 2006 | 08:03 PM
hova00's Avatar
I was looking for anyone that had solid info on what the compression numbers should be for a IX? I saw a post a few days ago about a IX with 140 across all cylinders, so i did a compression check on my IX to see where mine were at and would like to find out the specs. I tried searching but only find numbers about the 8.
Old Oct 26, 2006 | 06:36 AM
PessimiStick's Avatar
Should be identical to the VIII I think.
Old Oct 26, 2006 | 12:00 PM
Jamie@WORKS's Avatar
The service manual states 145 with a minimum of 92 and a variation of no more than 14 PSI. A bit different than the 163 of the VIII (138 min, variation is the same 14 PSI).
Old Oct 26, 2006 | 12:39 PM
Wow, not what I was expecting!
Old Oct 26, 2006 | 02:13 PM
cbrtrx's Avatar
yep my 9 was around 140psi in all cylinders, i was told thats normal
Old Oct 26, 2006 | 02:44 PM
boostedwrx's Avatar
why the lower compression on the 9s?
Old Oct 26, 2006 | 03:00 PM
aklucsarits's Avatar
Yeah... Why are the expected compression #s different for the IX?
Old Oct 26, 2006 | 03:01 PM
llxzxll's Avatar
compensation for larger turbo and mivec?
Old Oct 26, 2006 | 03:44 PM
But both the 8 and the 9 have the same static compression ratio 8.8:1 and the same stroke geometry.
What could explain the difference?
Old Oct 27, 2006 | 12:55 AM
tmodlin's Avatar
Seems low to me too. But if the manual states that then I guess it is
Damn engines are getting efficient of something lol. Nothing compared to my 92 4G63.
Old Oct 27, 2006 | 01:07 AM
94AWDcoupe's Avatar
The mivec accounts for the low compression when cranking. Mivec controls cam overlap. Obviously then the overlap is increased during cranking.
Old Oct 27, 2006 | 01:16 AM
tmodlin's Avatar
But doesnt a standard compression test just measure peak compression? It doesnt take overlap into its calculation. It is just a simple gauge that measures pressure.
EDIT: BTW, I am not doubting you 94AWD, just asking. Anyone that runs low 10s on pump gets my respect.
Old Oct 27, 2006 | 12:43 PM
hova00's Avatar
Then my motor is in good shape according to what you guys have said about the numbers.
Old Oct 27, 2006 | 01:53 PM
GregGSC's Avatar
the difference in the 9 is do to the longer durration and higher lift of the intake cam over a stock 8
Old Oct 27, 2006 | 01:59 PM
Mercenary3's Avatar
Overlap has nothing to do with static compression testing, only intake valve closing does, which is controlled by mivec along with overlap. So yes, mivec (and the longer intake duration) could be a large source of the lower compression, if not all of it....
