Any benifit to a 3.5" exhaust over a 3" ?
Originally Posted by GregGSC
the APS one is almost never instock in country. the only down side i see is clearnce issues.
I never had a 3" exhaust on the car so I can't really compare. I do know one thing though, my exhaust sounds really really good and I'm happy with it. Is there a big enough advantage to justify it's extra cost though?? If I were doing it all over again knowing what I know now, I would have probably just went with a 3" TBE and used the money I saved for other mods, but hey I'm happy with it. It still is holding up like the day I bought it and looks great..
Originally Posted by Lancerlover
If you're not running enough boost, you will lose back pressure which in turn will cause you to lose low end torque.
i built 2 exhausts for my car, one a 3" and one a 4"...i'll do a back to back next week when i dyno hopefully. Its not an Evo but a 2.0L honda. We have done a few 3.5" and 4" aluminum exhausts on Evo's but no comparisons yet...
Originally Posted by scott yo
i might be wrong or half right but didn't sheppard gain like 3-5 mph on his trap speed when he switched from 3in to 3.5 in? I'm not saying that you should expect a gain like that i just thought that was impressive!
Originally Posted by hondafan
in turbo cars, bigger is better. wether you'd make more power, probrably not without more boost and a larger turbo. in turbo cars, boost produces torque, not backpressure. the turbine gives all the backpressure you need.
3.5" exhaust is overkill on a stock turbo, period. If you can run 3.5" off the hot side of the turbo then do it but I know the stock turbo is much smaller than that already.
Stay with a 3" and dont waste your money. When you upgrade your turbo to something huge sell your 3" in the classifieds and go with something better. Until then, put your mod money toward something else.
Originally Posted by Bosshog
GUYS, this has all been tested before.
David Bushur gained a whopping 1HP when he took his 3'' exhaust completely off. This was on a car that had 300+WHP
Uhhh, I didn't say you would lose torque. I said you lose bottom end torque, and gain on the top end.
did he lose any torque? i'm doubting it even though sonicfadz thinks you would.
Actually, your wrong. If you look at any dyno sheet, a higher flowing manifold, exhaust cam, head, exhaust piping, always results in lower end torque/power and a larger top end. Yes the bigger piping will net more power but it won't yield much since the car we are talking about isn't powerful enough to BENEFIT from such a large exhaust. For there to be a substantial increase in power, the current exhaust has to be acting as a bottle neck. A 3 INCH EXHAUST IS NOT A BOTTLE NECK for A 300-400 HP CAR.
All the stuff you listed is BEFORE the turbo. Higher flowing manifold = high volume = lower exhaust velocity for a given mass flow rate = slower spool. Basically the same as using a bigger A/R turbine housing. Longer duration cams hurt lowend, head work generally increase the flow area which inturn reduces flow velocity through the ports which hurts lowend.
Even on NA, you don't want backpressure. It just happens that you need to keep exhaust velocites high for scavaging effects.... and to keep it high at low engine speeds means smaller diameter tubes which means higher backpressure. It's not the backpressure 'creating' torque, its the exhaust scavaging from the higher exhaust velocities.
