Car wont start due to blown fuse
I need help. The aem ignition box keeps blowing the inline fuse.
The car wont start obviously because of this. Any help from someone would be great. Not sure if its from the duell setting. The car has been running fine for the last month since I installed it.
help
anyone?
anyone?
I'd at least check the two o2 sensors, three if your running a wideband and see if the wires are ok
Good luck.
I never knew that. Thanks, I will check it out.
Originally Posted by RoadSpike
Common problem with blowing fuses is the o2 sensor wires make contact with the exhaust hosing and promptly bite the dust shorting out.
Good luck.
Good luck.
just installed my testpipe and cel fix on there. but i already got blown fuse twice.
maybe my 2nd o2 sensors wire are too close to my exhaust housing due to a cel fix.
thanks for your info man!
