Walboro 255 normal Pressure output?
Just wondering what sort of pressure a walboro should be putting out? My car is at the dealer right now trying to track down a leak and the tech felt like it might be putting out far too much pressure, he is reading it at 120 psi+!!!
Scorke
Scorke
if it's still bolted in the car, it shouldn't put out any more pressure than the regulator will allow. Base fuel pressure is 43#'s plus the boost/vacuum the manifold sees. The Walbro has an internal bypass valve that opens at 85 psi. It will put up more pressure than this if you dead head it, as the bypass alone doesn't flow enough fuel to keep pressure below 85 psi. But the fuel pressure regulator and the internal bypass on the pump should be more than enough to keep fuel pressure below 120#'s,. This is at a supplied voltage of 13.5 volts to the pump.
Turbo Magazine did a good write-up on various fuel pumps (Evo stock pump being one of them) in the Apr. 04 issue. The max they tested the pumps was up to 100 psi.
