AFR 21 at Idle.....
Old Nov 7, 2006 | 10:09 AM
BADEVO's Avatar
Originally Posted by Ev0ikon
Good that you confirmed it. It could be that the WideBand probe itself is going bad.
So what does it read when you stomp on it? Does it change from 21? If it doesn't, then you need a new WB sensor(should be around $60 is you looked hard)
If it DOES change then you have a tunning issue.
What injectors are you running? Anything special done to the motor/turbo?
It drops to a about maybe 14ish. Then when I get off throttle it goes right back up to 21. The car has 680 injectors.
The car just got an EVO IX turbo added last week, but I dont think that should make an issue while its at idle. But yeah we just did a swap the turbo for him.
Old Nov 7, 2006 | 10:13 AM
Evo_Jay's Avatar
Originally Posted by BADEVO
Did it stay at 21 or did yours start at 21 at idle and work down to 16 or 15ish?
Mine started at 14, then worked up to 21 and stayed there.
For real though, just go out and wiggle the cable. If the numbers flucuate, then you need a new sensor cord.
ALs, you should just email zeitonix. The guys always answers hella fast.
Old Nov 7, 2006 | 10:42 AM
BADEVO's Avatar
No luck on the cable wiggle. It holds dead solid at idle at 21.
My logs look as follows. This is from the drive to work.
O2Sensor
0.0585
0.039
0.0585
0.0585
0.0585
0.6435
0.819
0.8385
0.78
0.0975
0.0585
0.0975
0.624
0.7995
0.39
0.078
0.156
0.8385
0.8775
0.897
0.897
0.8775
0.858
0.858
0.702
0.0585
0.039
0.039
0.039
0.039
0.078
0.7995
0.897
0.897
0.897
0.8775
0.858
0.897
0.897
0.897
0.897
0.8775
0.8385
0.741
0.741
0.663
0.0975
0.039
0.039
0.039
0.0195
0.039
0.078
0.8775
0.9165
0.897
0.8775
0.7605
0.0975
0.039
0.039
0.039
0.039
0.039
0.0585
0.5265
0.858
0.858
0.8775
0.8775
0.7995
0.7995
0.819
0.78
0.234
0.078
0.0975
0.7995
0.7605
0.0975
0.4875
0.7995
0.195
0.624
0.8385
0.7605
0.195
0.8385
0.7995
0.7605
0.078
0.078
0.7995
0.819
0.156
0.39
0.8385
0.741
0.858
0.858
0.0195
0.0585
0.078
0.819
0.7995
0.78
0.741
0.195
0.078
0.078
0.078
0.078
0.0585
0.078
Old Nov 7, 2006 | 10:45 AM
BADEVO's Avatar
FTrimLow FuelTrim_Mid FuelTrim_High
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
100 121.09375 150
Old Nov 7, 2006 | 11:04 AM
PVD04's Avatar
It looks as though the injectors are scaled too big. Your idle fuel trim is maxed out (150 - In the latest release of Evoscan high and low fuel trims were mixed up). The 680cc injectors should probably be scaled around 570-610 depending on latency settings. I have my 780cc injectors scaled to 713 and from what I understand that is towards the high end of normal. I would work on rescaling the injectors to get those fuel trims in check.
-Paul
Old Nov 7, 2006 | 11:07 AM
BADEVO's Avatar
The injectors are scaled to 585
Old Nov 7, 2006 | 11:49 AM
Creamo3's Avatar
Do you possibly have an exhaust leak? That can throw off your reading depending how big of a leak there is.
Old Nov 7, 2006 | 11:51 AM
BADEVO's Avatar
I may have one at my Down pipe.
Old Nov 7, 2006 | 12:09 PM
TTP Engineering's Avatar
I asked you to pull your STFT with a pocketlogger.
You need to know what the ECU is trying to do.
You need to know if it is the WBO2 or the narrowband front sensor.
Without the STFT you will not be able to figure this out.
Old Nov 7, 2006 | 12:11 PM
BADEVO's Avatar
Well I dont have one and no one local does either so I had to order one. They dont do same day delivery. LOL
Old Nov 7, 2006 | 12:43 PM
PVD04's Avatar
You can use Evoscan to get short term fuel trims, although MalibuJack's Mitsulogger has it in a more usable form. The O2Feedback is the short term fuel trim.
-Paul
Old Nov 7, 2006 | 01:00 PM
BADEVO's Avatar
Well here are my O2 Feedbacks.
O2FeedbackTrim
103.125
104.6875
106.25
107.8125
109.375
110.15625
109.375
107.8125
107.03125
107.03125
107.8125
109.375
110.9375
110.15625
109.375
110.15625
111.71875
116.40625
112.5
109.375
105.46875
102.34375
99.21875
96.875
94.53125
95.3125
96.875
100
103.125
107.03125
110.15625
113.28125
111.71875
109.375
107.03125
104.6875
101.5625
98.4375
96.09375
92.1875
90.625
88.28125
86.71875
85.9375
84.375
83.59375
83.59375
85.15625
88.28125
89.0625
90.625
94.53125
100.78125
107.03125
100.78125
95.3125
89.84375
84.375
83.59375
89.0625
93.75
98.4375
103.90625
108.59375
115.625
121.875
121.09375
115.625
109.375
111.71875
106.25
100
96.09375
90.625
88.28125
95.3125
102.34375
109.375
103.90625
103.125
110.9375
108.59375
105.46875
112.5
110.15625
105.46875
103.90625
107.8125
102.34375
96.875
96.09375
96.09375
103.90625
98.4375
96.875
104.6875
103.125
96.875
60.15625
100
100
100
100
103.90625
107.03125
110.15625
114.0625
116.40625
114.0625
112.5
110.15625
109.375
112.5
114.84375
117.96875
121.09375
124.21875
127.34375
129.6875
128.90625
128.125
126.5625
125.78125
124.21875
123.4375
122.65625
121.875
122.65625
124.21875
125.78125
127.34375
127.34375
126.5625
125.78125
124.21875
123.4375
121.875
113.28125
112.5
110.9375
111.71875
113.28125
114.84375
116.40625
117.96875
117.1875
115.625
114.84375
113.28125
112.5
110.9375
110.15625
111.71875
113.28125
114.84375
117.1875
118.75
125
130.46875
135.15625
131.25
127.34375
128.125
132.8125
135.9375
129.6875
125
121.09375
115.625
120.3125
121.875
115.625
109.375
103.125
105.46875
113.28125
104.6875
103.90625
117.1875
109.375
100
90.625
80.46875
60.15625
60.15625
100
103.90625
110.9375
119.53125
129.6875
139.0625
139.0625
132.03125
122.65625
114.84375
107.03125
112.5
106.25
95.3125
88.28125
98.4375
86.71875
99.21875
89.0625
78.125
81.25
71.875
100
100
100
60.15625
98.4375
104.6875
113.28125
110.15625
103.90625
98.4375
92.1875
86.71875
81.25
78.90625
87.5
96.09375
93.75
99.21875
107.8125
103.90625
98.4375
107.03125
107.03125
103.90625
111.71875
109.375
103.125
107.03125
114.0625
111.71875
110.15625
118.75
114.84375
110.15625
115.625
114.0625
111.71875
120.3125
121.875
116.40625
113.28125
110.9375
105.46875
103.90625
107.8125
102.34375
96.875
103.90625
101.5625
98.4375
106.25
105.46875
100
94.53125
90.625
98.4375
100
94.53125
96.875
104.6875
103.125
98.4375
92.96875
88.28125
85.9375
92.1875
60.15625
60.15625
100
96.875
100.78125
104.6875
107.8125
111.71875
114.0625
111.71875
109.375
107.03125
105.46875
107.8125
111.71875
114.84375
118.75
120.3125
122.65625
122.65625
121.09375
119.53125
120.3125
118.75
117.96875
116.40625
115.625
114.0625
113.28125
111.71875
112.5
114.0625
115.625
117.1875
119.53125
121.09375
122.65625
121.09375
119.53125
118.75
117.1875
115.625
114.84375
114.0625
114.0625
112.5
110.9375
110.15625
108.59375
107.8125
108.59375
109.375
110.9375
112.5
113.28125
111.71875
110.9375
109.375
107.8125
107.03125
104.6875
106.25
107.8125
107.03125
106.25
106.25
107.8125
109.375
110.9375
109.375
108.59375
107.03125
107.03125
108.59375
109.375
110.9375
111.71875
110.9375
112.5
114.0625
115.625
116.40625
117.96875
119.53125
121.875
123.4375
123.4375
121.875
120.3125
Old Nov 7, 2006 | 01:21 PM
C6C6CH3vo's Avatar
Clean MAF wire with alcohol ?
nevermind, that would make it richer
o2 bad?
Old Nov 7, 2006 | 02:00 PM
TURBODAWG's Avatar
O2 feedback looks good. It looks to be the wideband that is bad or the wire like someone else suggested.
Brian
Old Nov 7, 2006 | 02:20 PM
bullfrg's Avatar
When I first picked up my new car it was showing 18-21 afr on my zeitrionix on start-up. It was also idling very rough and throwing a check engine light for the front 02 sensor. Replaced the sensor and still had the issue, Torquefreaks did some work on my car and found that Al had scaled the stock injectors incorrectly (680). Fixed the scaling solved the check engine light and fixed the idle issues on my car.
