Which should I buy Cams or Meth injection????
Old Nov 21, 2006 | 12:02 AM
  #31
kjewer1's Avatar
The point of meth is to get away with running more boost. Cams let you move more air without having to run more boost.
Cams provide what I call free HP. When you can move more air without raising boost, you don't get an increased tendency to knock. Raising boost on the other hand increases heat, which increases knock as well as airflow/power. Airflow is power, boost is heat. Intake manifolds and increased displacement are other popular methods of increasing airflow without raising boost, and both have done very well for me in the past.
Back to the cams, when I went to the 272s I picked up a solid 3 lbs/min airflow at the same boost level, which is consistent with what I have measured on the DSMs. That translated into 3 mph at the traps, as usual. Cams are good for solid reliable HP increase on a daily basis. Meth is more suited to wringing the last bit out of a turbo, or running higher than normal boost on pump gas and is the last thing I would do. It's like the nitrous vs FI arguement IMO. The cams are "always on." My 2 cents.
Old Nov 21, 2006 | 12:13 AM
  #32
TTP Engineering's Avatar
On the other hand you cannot run the same timing numbers on many types of aftermarket cams as you can on stock cams. There are some cam combos that need less timing than stock in order not to knock.
Just throwing a curve ball in your game.
Old Nov 21, 2006 | 12:14 AM
  #33
thisxguy's Avatar
Cams
Old Nov 22, 2006 | 07:17 AM
  #34
CaymanEvo3's Avatar
What about water injen? which one you think is better?
Old Nov 22, 2006 | 07:28 AM
  #35
4Gsixty3's Avatar
save alky for last.... definately do cams first!!
Old Nov 22, 2006 | 07:37 AM
  #36
34Turbo's Avatar
Cams w/ head studs. How are you going to run alky at 27-30 psi without having some head work done? Come on now...
Old Nov 26, 2006 | 05:31 PM
  #37
freddiet's Avatar
he said he wasn't shifting over 7 grand man
Old Nov 26, 2006 | 06:10 PM
  #38
Warrtalon's Avatar
Water Injen? Is that a new part by Injen?
Which one of what do we think is better? I don't see two things to choose from. The thread is asking about cams first or meth injection. The term meth can be substituted with alky, water, washer fluid, whatever...water won't make nearly as much power, so we usually use 100% alky or 100% meth.
Old Nov 26, 2006 | 11:25 PM
  #39
I think he should use goat milk injection. Injen has a new kit coming out.
Old Nov 27, 2006 | 07:48 AM
  #40
Zeus's Avatar
Old Nov 27, 2006 | 07:52 AM
  #41
h.funk's Avatar
I am doing my head gasket in a few days, so while i am in there i should be doing cams? Also do all cams need to upgrade the valve train?
Old Nov 27, 2006 | 09:57 AM
  #42
h.funk's Avatar
ttt
Old Nov 27, 2006 | 10:28 PM
  #43
kjewer1's Avatar
That certainly would be a good time to do the cams, since most of the work is already being done. As far as upgrading the valve train, that depends on the cams you choose. Check with the manufacturer/vendor/other users.
211Ratsbud
Jun 3, 2016 02:43 PM
bamboo_08
Northwest Region
45
Feb 10, 2008 01:10 AM
haseeb
14
Oct 12, 2007 02:32 PM
boomn29
28
Feb 14, 2007 10:29 AM
