For those that have installed a transmission cooler
Old Nov 27, 2006 | 07:25 AM
QuickOne's Avatar
in the MR 6-speed.... Where did you pick up the pump supply and return at? Did you tap the case directly?
Any pics?
Old Nov 27, 2006 | 07:39 AM
rcheung's Avatar
I wasn't aware you can even hookup a transmission cooler to a manual transmissioni.
Old Nov 27, 2006 | 07:41 AM
Zeus's Avatar
Yes you can, but it IS NOT for the novice! I've not even researched it for the Evo... it would be a HARDCORE mod for your race car.
Old Nov 27, 2006 | 07:54 AM
WhiteEvo05's Avatar
Check the road racing forum, a couple of track rats have done it.
Old Nov 27, 2006 | 07:59 AM
hondafan's Avatar
do a search under username razorlab. he just recently added a trans cooler to his 6-speed after having it rebuilt when the 4th gear sheered at the track. his thread on it has a parts list with part numbers and stuff.
Old Nov 27, 2006 | 08:13 AM
QuickOne's Avatar
I've found just about every thread that concerns a transmission cooler..
The problem is that I need to figure out where they get the pick ups from. No one (that i've seen) has yet to show that..
Old Nov 27, 2006 | 08:42 AM
barneyb's Avatar
Wouldn't the drain and fill plugs be ready made places for this? I think the bigger problem would be figuring out the proper fill amount since part of the oil is going to be in the pump circuit.
Old Nov 27, 2006 | 09:52 AM
hondafan's Avatar
check post 230 here and shoot him a PM with other questions as i'm sure he has it installed by now.
Old Nov 27, 2006 | 09:53 AM
QuickOne's Avatar
That was my guess, but, i kinda wanted to see what everyone else was doing before i went that route.
I also wanted to see how the fill plug was hooked up (if they used a "T" fitting or just replaced the plug..
