Engine shaking badly at stop!!
Old Nov 30, 2006 | 10:25 AM
ponstr123's Avatar
My engine is shaking badly when I come to a stop. Does anyone know what is causing this? Haven't had time to go to Mitsui yet...
Old Nov 30, 2006 | 10:27 AM
Smike's Avatar
Do you have any mods? I.E. VTA BOV?
Old Nov 30, 2006 | 10:37 AM
ponstr123's Avatar
I have an alarm with a turbo timer but i'm not using at the moment.
Old Nov 30, 2006 | 10:39 AM
smokedmustang's Avatar
Drives normal every other time? vac/boost leak? In neutral? Or IN GEAR with clutch in?
Old Nov 30, 2006 | 10:40 AM
Clutchdc5's Avatar
You blew an engine mount from launching
Old Nov 30, 2006 | 10:42 AM
ponstr123's Avatar
drives normal it only happen when I come to a stop with the gear in neutral and the clucth is not engage
Old Nov 30, 2006 | 10:44 AM
Sap12687's Avatar
Sounds like a mount to me. Maybe a loose crossmember?
Old Nov 30, 2006 | 10:46 AM
ponstr123's Avatar
let me check it out. I'll take another look at the crossmember and mount.
Old Nov 30, 2006 | 10:49 AM
Clutchdc5's Avatar
Yep has to be motor mount, violent shaking at stop, and if your moving the shaking cools down cause your lifting the engine off the mount, maybe that 1 mount blew, try to get a set of 4 , if u dd get softer ones
Old Nov 30, 2006 | 10:52 AM
ponstr123's Avatar
if it is the motor mount is that covered by warranty?
Old Nov 30, 2006 | 12:19 PM
ponstr123's Avatar
i recheck and everything is fine. The problem now come and goes. I can't figure it out it fine one minute then it not the next
Old Nov 30, 2006 | 12:23 PM
I agree with the boys above, motor mount is my guess also. Or outside chance a squirrell hung up in the alternator belt.
Old Nov 30, 2006 | 12:26 PM
Smike's Avatar
You might have to take it in the the dealer (as scary as that sounds) and take them on a test drive for a bit to see if you can get it to do it. Nothing is loose or disconected, broken (motor mounts look right)? No CEL?
Old Dec 1, 2006 | 04:36 AM
ponstr123's Avatar
hey guy here the update. the car is now fluttering at idle. When I drive off the highway and leave my turbo timer on the car flutter like it going to shut off. I check everything that could be a cause. NO Cel light yet and the dealers told me to leave the car there but the problem is they are not giving me a loaner car. Stupid Mitsubishi dealer. I also just had my alarm/remotestarter/turbo timer install about a week ago.. Could that be the problem? MY last resort is to take it to the dealer after I get out of work today.
Old Dec 1, 2006 | 05:12 AM
SteveosEvo's Avatar
Did the problem start right after the install of the alarm/remotestarter/turbo timer? If so then disconnect it to see if that fixes the problem.
