Turbo Help-Please
Old Nov 30, 2006 | 09:59 PM
silver3g2000's Avatar
Turbo Help-Please
Hey everyone, this is my first post. I have a 00' eclipse gs and am in the process of installing a turbo from an 04' Evo rs on it and need help telling which holes are for the oil and which are for the coolant. The banjo bolts were taken out and I need to find custom fittings for them. Can anyone post a picture idendifying which holes on the housing are for the oil feed, return, coolant feed and return? Also, would anyone know what the size of the openings are? Thanks in advance for the help.
Old Nov 30, 2006 | 10:06 PM
HPF Kyle's Avatar
the one with the the white residue is the coolant outlet. The port 180 from it is the coolant feed.
Now look at the other two holes...which ever one is bigger is your drain. The port 180 from that is your oil feed. I'd bet money they're all metric! lol
Old Nov 30, 2006 | 10:09 PM
thanks for the quick response, I'll take a look at it. Do you know where I can get fittings that screw into all those openings? The only thing I found was this: http://www.atpturbo.com/Merchant2/me...egory_Code=OIL
