Cam Question
Old May 19, 2003 | 04:19 AM
w2pac12345's Avatar
Question Cam Question
HKS makes two cams...2202-RM005 with a 272 cam duration and 10.3 cam lift in mm. The second one is the 2202-RM003. With a 264 cam duration and the same 10.3 cam lift in mm. What is the difference. What are the gains for each one? Which one is more practical for daily driving and there is a significant increase in higher end HP? Also is there a significant decrease in Lower RPM horses? Thnx. ALso im installing an intake, forge mtrsprt recirc BOV
Old May 19, 2003 | 12:54 PM
1QWKEVO's Avatar
272 are not street cams, you will have a nasty idle and the car will loud up if you set in traffic, best thing is probably to do what the Eclipses do and stagger the cames use a 272 exh cam and a 264 int cam. You don't need a 272 unless your running large turbos or at the track more then you are on the street. Then again why bother with cams right now either.....
