Install gone wrong?
Old Dec 11, 2006 | 05:29 AM
xLaNcErEvOx's Avatar
Install gone wrong?
So i just finished installing my 02housing and everything sounds good except for an exhaust leak which is fixable. While I test drove it, I heard some weird whining noise coming from under the hood, so i go back to the garage. I pop the hood open and manually press the throttle with my finger and I hear it coming from my intake (hks rs) after I release. It sounds like some metal is slightly grinding from the turbo. Anybody know what went wrong?
Old Dec 11, 2006 | 11:47 AM
bump
Old Dec 11, 2006 | 04:57 PM
bump again
Old Dec 11, 2006 | 05:00 PM
evopower1021's Avatar
call me man
Old Dec 11, 2006 | 05:02 PM
i will later tonight, my phone is being gay
Old Dec 11, 2006 | 05:04 PM
cool
Old Dec 11, 2006 | 05:05 PM
scottatyamaha's Avatar
Could be that your wastegate flapper is loose in the hotside of the turbo and is slapping around some or You left a bolt somewhere inside the hotside or O2 housing that just fubarded your turbo.
Old Dec 11, 2006 | 05:13 PM
i put the pin back into the hotside flapper so that its locked,
Old Dec 11, 2006 | 05:43 PM
before i found the problem, the car boosted fine. i ran 22 psi like normal, but wont do it again till it's fixed
Old Dec 11, 2006 | 08:31 PM
call me and come by tomorrow let me take a look at it.
Old Dec 11, 2006 | 08:55 PM
alright, ill try to call you and come by tomorrow.
Old Dec 13, 2006 | 06:55 AM
Kee1pride's Avatar
bump. is everything ok? i just saw this
Old Dec 13, 2006 | 08:03 AM
ries's Avatar
can you describe the sound??? is it like a metal-on-metal scraping/grinding or is it more of a whistling sound
if it sounds like metal-on-metal you might of dropped some kind of foreign object into the turboor intake and f-d up your turbo, honestly its hard to say w/ out further description
Old Dec 14, 2006 | 10:53 AM
WickedWhtMR's Avatar
please keep us posted on this.... i just got my O2 housing and im installing it the weekend. Dont want to do whatever it is you did. good luck
Old Dec 14, 2006 | 11:27 AM
Kee1pride's Avatar
any updates larry?
