So manifold cracked again!
Old Dec 15, 2006 | 06:56 AM
EVIL_EVO_VIII's Avatar
Red face So manifold cracked again!
So i discovered last week that my megan manifold has 2 huge cracks on it again !! My firsit one had 5 cracks in it when i took it out.. I havent removed it to see if its cracked anywhere else but im sure it probably is... I ran 12.43@109.86 with the manifold like this so im putting the stocker back on and going back to the track to see if i pick up any mph...
Old Dec 15, 2006 | 06:58 AM
SlowCar's Avatar
you do not have the hanger on right?
Old Dec 15, 2006 | 07:09 AM
Toddevo 8's Avatar
sorry to say it megan for you. you have an evo stop buying junk to put on your car.
Old Dec 15, 2006 | 07:17 AM
PPI's Avatar
PPI
You need a ported stock mani! Check out the link in my sig for different options
Unless there is a big Garret snail on my car I will be using a cast iron mani...slightly modified of course.
Old Dec 15, 2006 | 07:24 AM
No....
So how much gains can be gotten from the stock ported?
Old Dec 15, 2006 | 07:30 AM
PPI's Avatar
PPI
Gains of 7-15whp are common with just a manifold.
On my car I wasn't able to dyno afterward due to the shop closing down
So I took it to the track and found the gains of a ported manifold and my coated 02 housing.
Previous best was
11.57 @119 with 1.60 60ft
new best is
11.51 @120 with a worse 1.67 60ft.
The track doesn't lie! If my 60ft was the same that run would of been easy 11.4X
-Wayne
Old Dec 15, 2006 | 07:33 AM
Previous best was
new best is
-Wayne
Well i got a stock bushur ported one sitting at the house getting ready to go in today or tomorrow... Well see how this one works out as far as power gains
Old Dec 15, 2006 | 07:39 AM
rcheung's Avatar
I hardly consider megan junk. I have had the manifold over almost two years without issue. I did eventually port my stock manifold but wont change it out until the megan manifold does actually crack.
Old Dec 15, 2006 | 07:43 AM
Kee1pride's Avatar
hmm. we ran similar times. how can you find out if your manifold is cracked? are there any tests you can do?
PPI's Avatar
PPI
Nice, if you are interested in having it Swaint coated let me know...I could also gasket match it to your turbo hotside for the best flow!
Old Dec 15, 2006 | 07:46 AM
ibanez_926's Avatar
you cant really expect too much out of a 150 dollar manifold or whatever it costs
Old Dec 15, 2006 | 08:14 AM
Nice, if you are interested in having it Swaint coated let me know...I could also port match it to your hotside for the best flow!
the buschur one i believe is port matched
Kee1pride: The cracks are VERY visible
Old Dec 15, 2006 | 08:19 AM
HPF Kyle's Avatar
I'll buy the manifold off you...hit me up on PM.
Old Dec 15, 2006 | 08:20 AM
BADEVO's Avatar
You can buy mine if you want it....LOL
Old Dec 15, 2006 | 08:21 AM
u got a pm
