Which clutch
Old Dec 19, 2006 | 06:07 PM
tuning g's Avatar
Which clutch
Is there any clutch out there you guys recomend (twin disc) that dosn't rattle and make noise when on the clutch I need something that can handle about 450-500 whp and maybe go to the dragstrip 1 or 2 times a month please let me know.
thanks
Old Dec 19, 2006 | 06:10 PM
SIGSP2340's Avatar
Every twin disk I heard had chatter noise. Although, The Exedy Twin HD was probley one of the quieter ones I've heard.
Old Dec 19, 2006 | 07:10 PM
dorsalfin's Avatar
If you want a clutch thats going to be reliable your going to have to put up with the rattling
Old Dec 19, 2006 | 07:16 PM
tuning g's Avatar
Will the sd handle that much power or will it be a issue getting a sd at a great price or should I could hold out for a hd.
BTW there is a rumor about exedy clutches failing I personally know someone which this happened to but he still had in the ristrictor I dont know if htat could be the fault.
Thanks
Old Dec 19, 2006 | 07:20 PM
ROGERV's Avatar
just get the hd clutch from this vendor, they got the best price out there.
https://www.evolutionm.net/forums/sh...d.php?t=233643
Old Dec 19, 2006 | 07:23 PM
C6C6CH3vo's Avatar
Once you upgrade the stock clutch, not to mention add an additional 150 - 200WHP to get your goal, you must be willing to tolerate, rattles, noises, pops, BANGS!, stinkies, and so forth, not to mention breaks.
Just dont expect OEM engineered quality when you get there is what I'm pointing out - but I would say the Exedy twin is your best bet. I'm at about 340wtq with only the Stage 1 and it handles it fine (never used anything else thpough)
I bet the failing is due to bad engagement points of pedal adj - I almost started to toast my new clutch thinking the pedal adj was good but wasn't - poor adjusted engagement gives you responses you don't expect. Exedy - no cause fail
Big pouint is WHAT DO YOU WANT TO SPEND?
Old Dec 19, 2006 | 10:58 PM
evorace's Avatar
I know where to get one cheaper then them. It is the best clutch. I have one in my evo. Pm for details on where to get it.
Chad
Old Dec 19, 2006 | 11:00 PM
Ultimate CC's Avatar
cusco, stay away from exedy twin plate for over 500whp...
Old Dec 19, 2006 | 11:47 PM
Bom's Evo's Avatar
i just heard another cusco clutch. It's much louder than mine.
So Cusco can be quiet or not...We both have over 40k miles, but he has like 100+ drag runs...I love this clutch!
Old Dec 20, 2006 | 12:29 AM
vegasboy301's Avatar
triple carbon FTW
Old Dec 21, 2006 | 02:49 AM
Silk's Avatar
Arent they basically the same clutch though?
Old Dec 21, 2006 | 08:53 AM
Chris@nolimitmotors's Avatar
Why the cusco is made by Exedy, its the same as the Exedy SD twin disc. The Cusco will hold less power then the Exedy HD twin will.
Old Dec 21, 2006 | 10:23 AM
MitsuJoe's Avatar
To do 500whp you should really look at a triple plate or larger. In reality it depends on how you race the car and what you plan to do with it.
All twin discs will chatter and have decel noise. This is a trade-off to hold more power.
Old Dec 21, 2006 | 11:43 AM
Smogrunner's Avatar
Originally Posted by vegasboy301
triple carbon FTW
Worst advice ever.
I'm starting to think that Evos were built to keep the entire overpriced aftermarket clutch industry afloat. $1,500 here, 3,500 hundred there, for a clutch?? No way. We spend WAY to much money on clutches. I, for one, victimized myself in this regard and I'm about to make it my mission on EvoMessageBoardLand to help us all save some money.
Old Dec 21, 2006 | 12:22 PM
MitsuJoe's Avatar
Originally Posted by Smogrunner
Worst advice ever.
Your fricken mod list deserves a triple plate, it just sucks how much you have to pay for one.
