Boost goes to 29psi in the 2-step!!
Old Dec 20, 2006 | 12:14 PM
KazzEvo8's Avatar
Disassemble, inspect, and clean the MBC.
Old Dec 20, 2006 | 12:15 PM
Nez136's Avatar
Im thinking maybe the gauge is a little off b/c 29psi is kind of big for the amount of exhaust gas you get from a 2 step. Its been known that some gauges go to sh|t after a while. If it smells like fuel then you are probably knocking for sure....unless you have some kind of a fuel leak.
Old Dec 20, 2006 | 12:18 PM
EVIL_EVO_VIII's Avatar
Im gona take the boost controller off and clean it to see if it helps
Old Dec 20, 2006 | 12:21 PM
Nez136's Avatar
Take it off and run off WG pressure just to see what your gauge reads. should be just under 1 bar at full boost
Old Dec 20, 2006 | 12:32 PM
U mean disconnect the line from the mbc that goes to the wga?
Old Dec 20, 2006 | 12:35 PM
vegasboy301's Avatar
mine dumps fuel sometimes as well. but it just shoots mad fireballs and black smoke. then dies...
i dont use my two step much though... i can launch fine without it
Old Dec 20, 2006 | 12:38 PM
Nez136's Avatar
I believe thats how you do it, in which case the WG isn't connected to anything, then you should be hitting i believe 11-12 psi on the stock turbo, somebody can correct me if im wrong, its been a while since the stock turbo says for me.
Old Dec 20, 2006 | 12:44 PM
heres mine
Click here to see Video
it usually tries to die after this happens
Old Dec 20, 2006 | 12:45 PM
joeymia's Avatar
jeez it has nothing to do with boost control. you were on 2-step for to long timming got pulled and unburnt fuel was exploding in your manifold. not a very smart thing to do btw...
Old Dec 20, 2006 | 12:48 PM
Mivecless's Avatar
Correct, half the fuel is unburnt out the exhaust and explodes before the turbine blades.
Old Dec 20, 2006 | 01:13 PM
lol
Old Dec 20, 2006 | 01:39 PM
joeymia's Avatar
Originally Posted by vegasboy301
lol
Why are you laughing... 10-15 seconds on 2-step will cause problems and in some cases cause knock to be detected. BTW here is my personal car with 15 degrees of ignition retarded.
http://72.41.83.159/video/msd-ignition-retard.wmv
Those are 15+psi spikes within 2-3 seconds. You don't need to to rev any longer than that.
Old Dec 20, 2006 | 01:59 PM
check out my video a couple posts up (post #23)
sup with that
Old Dec 20, 2006 | 02:11 PM
joeymia's Avatar
dude nothing is up with that... you yourself admit your car stalls. How is that good for your car and you can't launch it either. That tells me your **** doesn't work. Your car just like EVIL_EVO_VIII is having its timing pulled due to the detection of knock.
Old Dec 26, 2006 | 02:02 PM
SilverEvo8owner's Avatar
When this happens, is the car actually knocking or is it just detecting the fuel in the exhaust exploding?
