Downpipes with flex sections. A question.
Old Dec 22, 2006 | 04:31 PM
MondoBongo's Avatar
I searched and couldn't find and answer to this, i guess i am looking for opinions and expierience.
i am going to be getting a TBE soon and i was wondering how important it was to get a downpipe with a flex section?
i live in pennsylvania, so the roads around here are pretty rough in alot places.
I've noticed that most of the downpipes i have run across while shopping don't include a flex section, and i haven't specifically heard of anyone having major issues because of this.
can anyone tell me to the contrary?
Old Dec 22, 2006 | 05:34 PM
riceball777's Avatar
it really depends
i think if you have a tubular manifold you should have a flex on the exhaust because when the exhaust moves the stress would all be plaiced on the tubo manifold.
log manifold are probably fine with out one
Old Dec 22, 2006 | 06:22 PM
fimotorsports's Avatar
if you have a doughnut gasket that goes between the 02 housing and downpipe, that acts as a flex section as it allows movement between the engine and exhaust
Old Dec 22, 2006 | 06:37 PM
MondoBongo's Avatar
thanks guys.
Old Dec 22, 2006 | 06:53 PM
Xfer's Avatar
My exhaust is a full 3" Ichiba with the flex section. It was a tight fit near the oil pan, but I have not had any problems with it. Had it for about 4k miles...
Old Dec 22, 2006 | 09:28 PM
evotico's Avatar
Same here. I got the Megan DP with Flex tight fit. No problems so far. Knock on wood>
Old Dec 28, 2006 | 05:15 AM
MitsuJoe's Avatar
A lack of flex section is really because the EVO has more of a solid stock motor mount. Also the stock design uses a crush spring/bolt to give play to the exhaust. These coupled together means you do not need a flex section. It will not hurt anything although it may have clearence issues on some cars.
