odd boosting problems
Old Dec 24, 2006 | 06:30 AM
EvoDan2004's Avatar
ok last nite the car was fine. all day. it was pulling hard as normal. then all of a sudden it wont boost past 14psi. any gear and rpm anytime it just wont boost past 14 psi. car runs fine. idle's fine. when i jump on it it runs fine. no smoke no braking up. its like it was ment to run on 14 psi. even the afr's are low 11's. car has a forge mbc and a forge waste gate with 19 to 24 psi spring. mbc has heavy spring. car was perfect then this happen. i did not touch anything. any idea's? tia
boost leak check. holds 26psi firm
Old Dec 24, 2006 | 06:34 AM
EMonz57's Avatar
Is it at all possible the sprin on the waistegate can get stuck?? Just tossing out an idea
MBC wont change the boost either?
Old Dec 24, 2006 | 06:43 AM
bluepeartype-s's Avatar
Registered User
Throwing this out.I see you have a LICP..did maybe one of our pipes blow off during boost?? Your car was still able to drive right? whoops ignore me I'm not read properly.
Old Dec 24, 2006 | 06:44 AM
EvoDan2004's Avatar
i have no idea on the waste gate spring. i turned the mbc up 3 clicks and same thing. nothing but 14 psi.
Old Dec 24, 2006 | 06:45 AM
EvoDan2004's Avatar
car runs pefect other then boost. it runs as if it was set like this. as for my licp i did a boost leak test up to 26 psi. holds firm
Old Dec 24, 2006 | 07:20 AM
Evoryder's Avatar
your car is pulling the same? have u checked your boost gauge?
Old Dec 24, 2006 | 07:23 AM
EvoDan2004's Avatar
no no no no no maby i miss worded myself. car runs the same. it does not pull like it did on normal boost. it runs perfect. just dont boost normal. it dont pull like it did. im running 14psi not 22. understand???
Old Dec 24, 2006 | 08:35 AM
cij911's Avatar
My guess is that you have a leak or your WGA is just open...
Old Dec 24, 2006 | 10:22 AM
spln*up's Avatar
try checking the vacum line to the wastegate. it might be off or crack thus giving you only the wga spring boost limit.
Old Dec 24, 2006 | 10:41 AM
Evoryder's Avatar
definetly sounds like a wastegte issue...and the system just consistently holds the boost? weird get a friends mbc on there to eliminate that factor
Old Dec 24, 2006 | 10:45 AM
Evo05lution's Avatar
check the hose that runs from the MBC to the wastegate actuator...it seems like one of the vacum lines popped off somewhere...give it a try.
Old Dec 24, 2006 | 11:35 AM
EvoDan2004's Avatar
well i took the mbc out of the car. i took it apart and regreased it. seems the problem is solved. why it was happening i dont no. when i took it apart the spring was seated right and it was not dirty. nothing was cloged but whatever. its fixed. as i took the mbc i checked all the lines. there fine. see what happen's in a day or so.
galantman03
43
Feb 5, 2017 09:54 PM
svt_lightning01
Mar 31, 2011 01:08 PM
VIIImylunch
11
Jun 11, 2006 07:24 PM
AzBlackEvo8
18
Dec 29, 2005 09:02 PM
scottatyamaha
16
Feb 28, 2004 07:34 AM
