!!!why is my greddy rs bov keeps fluttering
Old Jan 4, 2007 | 01:22 PM
jspecEVO's Avatar
What i did!
I took the smaller spring out of the BOV and adjusted it acordinly. It works fine now!
Old Jan 4, 2007 | 01:24 PM
400awhp16g's Avatar
Does hks flutter too???
Old Jan 5, 2007 | 10:19 PM
Jie-EVO's Avatar
i did try to loosen it but it still does the same thing!!
i just find out that it woosh and low rpm and flutters at more then 0.5 kpa!!!
please help me out should i tide it more or loose it more i really want my woosh back!!!
Old Jan 6, 2007 | 01:24 PM
jspecEVO's Avatar
Dude!
Did you not research this piece of @*%%^! The best thing that worked for me was to remove on of the spring like I said earlie. It will then work. The only thing is with this bov the diaphram insid cracks even when it is left with both springs on it. I seen it happen more than once. Not the best bov on the market. I have one sitting in my trunk for about a year and it is brandnew!
Old Jan 6, 2007 | 01:27 PM
SuperBoostGuy's Avatar
All after market BOV flutters.... my HKS is a fluttering SOB
Old Jan 6, 2007 | 01:30 PM
GraphanaticIXSE's Avatar
BOV's have a 'sweet spot'. Adjust it until you find it, or get another one. HKS SSQV is what I got and I have no problems with flutter. Good luck.
Old Jan 23, 2007 | 03:08 PM
Recks's Avatar
Yeah don't losen it to much you will have boost leak
Old Jan 23, 2007 | 03:13 PM
boostinjuice's Avatar
is it in correctly... did you put it in backwards...75 % of people think they put it in correctly and its wrong.. thats what causes flutter.. same thing that happened to me.. then found out the person who put it in had it in backwards...
Old Jan 23, 2007 | 03:23 PM
evoteddy111's Avatar
i rather have the flutter than the woosh, i think the type s sounds so good...is there a bov thread, like the exhaust threads for vids n such????
Old Jan 23, 2007 | 10:57 PM
EvOcHaRgeR's Avatar
I have a tial and it flutters in low rpms of 1-3rpms then stops when going WOT! However, it does flutter some during partial throttle. In addition, it gives me some idle issues keeps hunting or drops down like it wants to stall.
Old Jan 24, 2007 | 08:01 AM
noticed you made a post about your greddy fluttering now matter what you did to try and eliminate it.. same thing happened to me.. you have the bov in backwards..the blue recirucultion part of the bov should be in the lower tube and so that the top where the adjustable screw is is facing the exhaust manifold
should look like this!!
Old Jan 24, 2007 | 08:03 AM
saiyanzzrage's Avatar
Jesus Christ, you replaced arguably the best bov on the market that CAME WITH YOUR CAR for a piece of crap noisemaker. You get what you deserve. Why did you replace your stock bov? plan on running higher that 25 psi? doubtful. Damn ricers.
Old Jan 24, 2007 | 08:18 AM
+1
your stock 9 bov is best bov up to 25PSI
Old Jan 24, 2007 | 08:19 AM
hondafan's Avatar
Originally Posted by Rez90
the greddy type RS sucks. I wish they still made the type S. That was a great BOV with a great sound as well.
+1, that's what i run. and yes, i tried the RS before that.
Old Jan 24, 2007 | 08:21 AM
Spooldyou's Avatar
all bov's flutter.
