turbo install advice
Old Jan 9, 2007 | 07:24 PM
dashiet's Avatar
hey, im planning on installing my turbo kit tomorrow. turbo, exhaust manifold,licp, wastegate. is there anything i should know before i start working on it? i want to make a checklist of what should be done so i dont make a big mess or forget to do something. i have already done a search, and i have not found anything on how-to's and install thread. thanks guys, ill post pictures when im done withing a few days.
Old Jan 9, 2007 | 09:44 PM
evo150's Avatar
what turbo are you installing?
Old Jan 9, 2007 | 10:00 PM
dashiet's Avatar
gt3567r .82 a/r with meth
Old Jan 9, 2007 | 10:04 PM
whitersevo's Avatar
make sure the crush washers are crushed correctly, and make sure your oil line and return lines are tight so they do not leak, also make sure you boost leak test it after the install, that is bout it, do not over tighten the studs to the manifold.
Old Jan 9, 2007 | 10:06 PM
dashiet's Avatar
cool thanks whitersevo. and im assuming drain engine oil, drain radiator fluid, and remove radiator also?
