supertech dual valve springs?
Old Jan 23, 2007 | 08:46 AM
strokedt67's Avatar
How good are they and what can you safely turn the motor to with them installed.
Anbody have a link to a comparision done of different springs?
Old Jan 23, 2007 | 08:53 AM
Chris@nolimitmotors's Avatar
They are great, we have had nothing but great results with them. We have them in our skyline reving over 9k.
Old Jan 23, 2007 | 08:55 AM
Steve@NoLimitmotors's Avatar
i have a customer with supertech valvetrain going up to 9800 on a built 2.0 with removed balance shafts and a PT6776 P trim (GT37R)
Old Jan 23, 2007 | 09:56 AM
GregGSC's Avatar
We have tested a TON of different evo springs here and we have found the supertechs to be the most stable.
The only down side to the dual springs is that they require new valves seals and of course new seats. these are good to 10500.
The Supertech single springs are also very good. same pressure as the dual not as stable as the duals though, they dont require new seals, or new seats. they can be run as high as 8500 with out extra harmonics.
Old Feb 29, 2008 | 12:10 AM
Inprogress's Avatar
So for someone running a stock or stockish turbo, the Supertech Singles would be all they'd need. I'm beginning to consider these for the ease of install and that they don't need anything extra.
The supertech singles don't need anything extra to be installed right? Just get the springs+retainers and call it a day?
Old Mar 1, 2008 | 09:34 PM
Inprogress's Avatar
Anyone have an answer to the above?? ^
Old Mar 1, 2008 | 09:40 PM
psphinx81's Avatar
correct, u shouldnt be revving to 8500 on the stock rod bolts anyway. youre risking a lot by going that high on them. id say 8k would be the limit. at the track i rev to 8k on the stock valvetrain, on the street i really try not to push over 7700
Old Mar 1, 2008 | 09:44 PM
Inprogress's Avatar
So all that is needed for the install on a set of single springs is just the springs+retainers and that's it?
Old Mar 2, 2008 | 07:45 AM
psphinx81's Avatar
u got it
Old Mar 27, 2008 | 10:25 PM
NewEvolutionIX's Avatar
Now Im looking into getting 272 cams. I have a stock turbo for now and Im looking into the new FP green. But before that I want to get the head done. So im looking into springs/retainers, and valves. Would it be worth it to get these dual springs and retainers? And get the seats and seals sense they are need. Then have the car tuned to rev to 9k? I know its not that good for the rod bolts but if I were to get APR rod bolts would I be good then, or is that just to much for the engine?? And when doing this is there anything else I should look into doing. Like 5 angle valve job?Port and Polish?
Old Mar 29, 2008 | 11:42 PM
hanahawaiian's Avatar
I have those supertech Dual spring and retainer also Seal kits... with Cosworth M3 spec 280/272 and it amazed and have no problem over 1400 miles so far
badev0
Dec 28, 2016 08:51 AM
surferjeff
11
Apr 11, 2015 12:11 PM
jeromski2003
Jun 11, 2010 10:01 PM
Johnny Boy
20
Jan 9, 2006 09:34 AM
03LancerOZRally
12
Apr 2, 2003 06:04 PM
