problem with acd
Old Feb 1, 2007 | 08:51 PM
ideogniem's Avatar
problem with acd
Hi,
I've 06 EVO and I got it with broken transfer case and possibly this "acd" pump.
Ive rebuilt the transfer case but need the pump. The "gravel, tarmac, snow" lights are flashing all together - it should be one at a time.
Is this beacause broken pump?
Where can I buy this pump? Mitsubishi sells only with transfer case!
Is because of broken pump car runs in some kind safe mode?
Old Feb 1, 2007 | 08:56 PM
eponti's Avatar
06? Should be under warranty,take it back to the dealership
Old Feb 1, 2007 | 09:06 PM
ideogniem's Avatar
someone messed up with oil in tcase so propably this is a reason why it was broken and also the pump, so as far as i know it is not a warranty repair because someone forgot about oil in tcase.
Old Feb 1, 2007 | 09:28 PM
gunzo's Avatar
The Tcase and the ACD pump are 2 separate issues..
If you're not running dry on ACD pump fluid (which uses ATF), the rest of the system should be okay.. the ACD pump container should be in your boot on the driver side
Please search under ACD lights flashing as I posted somewhere in the Advanced forum regarding the meaning of the flashing lights ..
