The competitions coming..so AMS and Buschur Racing teamed up....
duuuuuude DB has it figured out. now to only fill your tank with this:
Nitromethane
From Wikipedia, the free encyclopedia
Use as an engine fuel
Nitromethane is used as a fuel in racing, particularly drag racing, to provide more power.[2] In this context, it is commonly referred to as "nitro" or just "fuel".
The oxygen content of nitromethane enables it to burn with much less atmospheric oxygen in comparison to hydrocarbons such as gasoline:
4CH3NO2 + 3O2 → 4CO2 + 6H2O + 2N2
14.6 kg of air are required to burn one kg of gasoline, but only 1.7 kg of air for one kg of nitromethane. Since an engine’s cylinder can only contain a limited amount of air on each stroke, 8.7 times more nitromethane than gasoline can be burned in one stroke. However, nitromethane has a lower energy density. Gasoline provides about 42-44 MJ/kg, nitromethane provides only 11.3 MJ/kg. This analysis indicates that nitromethane generates about 2.3 times the power of gasoline when combined with a given amount of oxygen.
2.3x the power of gas. so lets see, that makes DBs drag car now have what? 2300 hp?
(hahaha on a side note, if you needed 1600cc injectors before, you're now gonna need those walboros on each cylinder. or else try and find 13,000cc injectors. hahahahaha)
Nitromethane
How about using your snorkel idea to ram air into the top of the tank to force more fuel out the bottom. That way the faster you go the more fuel you force out.
Julio, did you see the picture of this joint venture fuel system we built? My God we DID raise the bar!!
BTW, I have to give Julio some props, seriously. He was MAN ENOUGH to call me and speak with me on the phone. He has more ***** than anyone else I have run into on EVOm in a very very long time. I did explain this is a joke and that any time someone makes a statement like he did I consider it a threat. Julio, no hard feelings, I alteast respect you for calling me. See you in August.
For those interested in this setup with some extra pocket change this is now available on our website for sale.
https://secure.buschurracing.com/cat...535087eacae92a
Jarrod, I know your pretty dead on with your pricing, but I was wondering if we could get in on a group buy with your lovely new product.
Edit* wrong name...
ok I know I'm new here but I have the ULTIMATE fuel set up and it is friendly to environment... Its an *** injectected meth kit...ok you take the roof mounted fuel cell design with Dave's 6 pump set up for max gravity feed and injection pulse..now instead of using a seprate tank for meth injection you take the recirculaton valve put a splitter on it so only half of the spent air is recirculated...place a hose on the now split recirc.valve, run said hose to your mouth..upon shifting you get a blast of air that fills you up causing a huge nasty fart..which we all know is methine gas...take another hose from your *** to a serge tank to be injected to fuel mix...how that is done I'll leave up to the engineers.
