Go Fast Bits Bov ????
Old Feb 3, 2007 | 09:32 PM
Jackson's MMA's Avatar
I just purchased the Go Fast Bits Stealth FX from the Lancer Shop. They are closed for the weekend, that is why I'm posting. It is listed as a direct bolt on, however it seems too big using the mounting gasket and screws (leaking). Has anyone installed this particular BOV and am I missing something????
Old Feb 4, 2007 | 08:54 AM
GoneIn420's Avatar
Hmmm, I had no problem installing mine. It fit just like the stocker, the unit was just a little bigger but the ports were the same size and in the same place. I am not sure what gaskets you are talking about, the BOV it should come in one piece and no assembly is required. Make sure that the unit is installed laying flat, ie: the blow off horn points to the hood and the top (silver spring adjustment knob) points to the radiator and the bottom outlet goes to the intake. Peace.
