Need Help with Trany/ACD Fluids, MR
its a 2005 MR
Need some help with all the oils in the car ( motor, Transfer Case, ACD, Brake Fluid, Power Steering, I think that's all that's in the front ) so its time to put the hole front together and I am confused on the transfer case / ACD / Trany fluid, ok so I got the big jug from the dealer for the trany, and they told me I need Automatic Trany fluid for the ACD, witch I also got from the Mits Dealer, so is there transfer case fluid also? or the trany and the transfer case uses the same oil? as there is a little oil hole that's on the transfer case that runs back to the transmission?
Thank you!
Thank you!
For the tcase and rear diff you need the special Mitsu Diaqueen for the MR. It looks like this:
http://lancershop.com/customer/produ...&cat=15&page=1
Now make sure you get that one and not the other Diaqueen for the RS' and GSRs. It is expensive, but hey, what can ya do.
I do stock it, and with the EvoM discount, it goes for $69 change plus shipping.
The "Super Diaqueen" or "GL-4" that you just linked is just for the MR 6-speed transmission.
For the T-case and rear diff, it takes the regular "GL-5" LSD oil just like the other Evos.
GL-4 for 6-speed. It is in an all white can with a japanese palcard on the front (no mentioning of GL4 or super diaqueen)
GL-5 for the T-case and Rear diff. It is a white can w/ red markings and the words "Diaqueen LSD Gear Oil" on the front. If they sold you this, don't put it in your tranny....just T-case and rear diff.
**Also, the drain and fill plug for the 6-speed tranny are 10mm hex key/allen (IIRC).
GL-4 for 6-speed. GL-5 for the T-case and Rear diff.
