Which cables do you use when hooking up aftermarket rad fans?
Old Feb 7, 2007 | 10:17 AM
ZyBeR's Avatar
The stock rad fan connector have 3 cables, two big (blue & black) and one small (blue).
I used the two big ones and just left the small one out. But I can't controll my fans through the AEM, they are always on.
How have you guys done it?
According to AEMs manual rad fan should be controlled through LS2, but no luck.. I've tried all outputs in the output menu and I get no response...
I need to fix this, can it be the Euro spec uses other pin # for the rad fan? I tried to check (beep) with a multimeter but no luck, it beeps on 9 pins on just the first connector. I guess that's just becourse ign is off and much electrical stuff is grounded..
I know some one here can help me, so shoot guys =)
Old Feb 7, 2007 | 12:10 PM
WaxThis2005's Avatar
Maybe you forgot to connect the blue to blue, black to black ex...... Or you didnt connect a wire.
Old Feb 7, 2007 | 01:44 PM
ZyBeR's Avatar
The fans are working, but they are on all the time... I haven't driven the car so I don't know if they turn of some time, but they are on from start...
I did not connect the thin blu wire but the only thing I could have connected that to was the big blue.. I thing the problem is with the contreoll of the relay..
Old Jul 29, 2007 | 06:52 PM
KOM88's Avatar
i would rely like some help with this as well
