100oct in tank and afr's are LEAN
ok i just put 100oct in my car. the tank was empty. i normaly run 93oct and my afr's are from 11.4 11.5 to 11.1 10.9 at red line.
now with the 100oct in the tank my afr's are 11.8 12.2. im running the same boost 23psi..
i am also tuned.
i was told i can put 100oct in the car and turn the boost up a bit. i did not do so because it is already to lean i think. so whats going on here???? help would be great
i am also tuned.
Thats beyond strange. I have no idea what could be the problem as it should not to that. Higher octane (or lower) should not affect AFRs. Running 100+octane should allow you to run leaner because it burns slower (and you can turn up the boost).
well i am lean right now. with 100oct in the car. im like 12.2 12.0 at wot. i did not turn the boost up. still on 23 psi
car is tunned. i run 93 oct and my afr's are normaly around 11.4 and 10.9 to redline running 23psi
i then filled the tank with 100oct and my afr's when leaner. 12.2 to 12.0 at the same boost leavels
