injectors OR cams???
Old Feb 11, 2007 | 02:39 PM
OnAll4's's Avatar
My vote is for cams, and the brand is up to you!!
Old Feb 11, 2007 | 02:44 PM
Nez136's Avatar
You will run out of fuel, so there is no point to getting cams if your not getting upgraded injectors or Alky
Old Feb 11, 2007 | 03:19 PM
Recks's Avatar
What model do you have? 8 9? That will dictate what cams to get
Old Feb 11, 2007 | 03:23 PM
evobeatsti's Avatar
do you have an VIII or IX we need to know that first before you start shopping for cams. as of now only gsc and cosworth make ix cams while there are tons of companies that make VIII cams also what is your car used most for? we need to know this before we can suggest you a good set of cams for your needs...
Old Feb 11, 2007 | 03:27 PM
ries's Avatar
I dont think this is entirely true...the only way to be sure is to run a log and find out what the actual duty cycle % is....
I think you will be able to get away w/ the stock injectors on straight pump....but I know for sure you wont need injectors if you go w/ alky or meth
