They make a 2.4 stroker?
Old Feb 19, 2007 | 09:47 PM
MR. Birdie's Avatar
I always thought that the 2.4 is a different block from the 4g63. I went through this vendor site called JSC and they have a 2.4 liter stroker from crowerr.
http://www.jscspeed.com/evo/evo_base...bc_stroker.htm
that's the link to the kit. Any input to this stroker kit? how is this better then the 2.3 stroker.
Old Feb 19, 2007 | 09:58 PM
Frenchy4g63's Avatar
It has a crank with a longer stroke, 104mm I believe.
IMO I think that's too much, just kills your top end.
Old Feb 19, 2007 | 09:59 PM
Ultimate CC's Avatar
yea i wouldn't do more than an ams 2.3
Old Feb 19, 2007 | 10:10 PM
MR. Birdie's Avatar
kool thanx for the feed back. I was just wondering and ran across this stroker.
Old Feb 19, 2007 | 10:13 PM
Vigo's Avatar
There is the Brian Crower 2.4 liter stroker kit, which has a 102mm stroker crank and 86mm pistons. With that kit piston speeds will be too high, because of the high stroke.
You can also opt for a built 4G64 motor, which is 2.4 liters unmodified. The 4G64 has the Mitsubishi crank found is the AMS and Buschur Racing 2.3 liter stroker kits. With the 4G64 you will have the same RPM potential and piston speeds of both the non Road Race version of the AMS kit and the Buschur Racing kit.
Personally I would go for the built 4G64 short block from Road Race Engineering. With that much displacement you will be able to reach 20psi at 3600rpm with a GT35R and safely rev to 7600rpm.
Old Feb 19, 2007 | 10:23 PM
MR. Birdie's Avatar
kool
Old Feb 19, 2007 | 11:41 PM
Vigo's Avatar
Road Race Engineering is located in 13022 la dana ct. Santa fe springs, ca. 90670.
Old Feb 20, 2007 | 12:14 AM
StatixNWH's Avatar
2.3 ams is where its at
Old Feb 20, 2007 | 08:47 AM
jmartinez1170's Avatar
AMS is on our vendor marketplace. They are based out of chicago.
Go to there site and check it out.
Old Feb 20, 2007 | 08:51 AM
dsevo's Avatar
Mr. Birdie is in California. I deffinitely reccomend talking to Road/Race if your serious about a new motor. I've dealt with them on multiple occassions, and they are a top notch group of people, with reasonable prices to boot.
Old Feb 20, 2007 | 08:55 AM
hks-evo's Avatar
you can do a 2.4 bottom end but you would have to swap your evo 8 head .and yes its been done
Old Feb 20, 2007 | 09:53 AM
MR. Birdie's Avatar
What does it take to get the 2.4 block to work with the evo 9 head? Isn't there alot of work that need to be done? Tuning Technologies are going to do the motor work and tuning for me. Since I been dealing with them for a long time. I want a reliable block.
Old Feb 20, 2007 | 03:29 PM
Vigo's Avatar
Just give Road Race Engineering a call, or better yet, just go to their shop. They are located in SoCal. I just gave you the their address.
Old Feb 20, 2007 | 05:18 PM
Jackson Machine's Avatar
Check out our website for our stroker kits. We offer 3 different stages.
Old Feb 20, 2007 | 05:33 PM
Paul Nelson's Avatar
